Current Revision
Current Revision
Current Revision
got a very unusual issue.
My current revision on the sheet does not display. It shows question (?) marks as if it was unrecognised parameter.
It works on most of the projects but there is something wrong on like 15 projects where the issue is persistant. Those 15 project were created from the same template (so there is something wrong with the template)... However, it is still very strange since it is a system parameter.
Do you know how to solve it? I would really appreciate, since we are changing the titleblocks on the project which is half way through.
Thank you in advance. See pictures attached.
Kind regards,
Vitalij
rosalesduquej
Hi Vitalij,
Is this a Revit API related question? Revit API forum is for API (Application Programming Interface) questions.
For non-API questions, please choose other forums that is more appropriate. For example,
Installation and licensing:
http://forums.autodesk.com/t5/installation-licensing/bd-p/24
Revit Architecture (including common platform product usage questions):
http://forums.autodesk.com/t5/revit-architecture/bd-p/133
Revit Structure:
http://forums.autodesk.com/t5/revit-structure/bd-p/153
Revit MEP:
http://forums.autodesk.com/t5/revit-mep/bd-p/188
Cheers,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
