Creating Solid with one PlanarFace using BRepBuilder based on slab sketch
andhxl
Message 1 of 16
andhxl
I need to create a Solid with a single PlanarFace using BRepBuilder.
A PlanarFace Edges based on a curves from sketch of a slab.
Below is the code of how I do it. I get the error "Autodesk.Revit.Exceptions.InvalidOperationException: 'BRep doesn't have enough faces.'" on brepBuilder.Finish();.
I do not understand how to create disconnected Solid with one PlanarFace (highlighted in red in the screenshot).
var brepBuilder = new BRepBuilder(BRepType.Solid);
var surface = BRepBuilderSurfaceGeometry.Create(sketch.SketchPlane.GetPlane(), null);
BRepBuilderGeometryId faceId = brepBuilder.AddFace(surface, false);
foreach (CurveArray ca in sketch.Profile)
    BRepBuilderGeometryId loopId = brepBuilder.AddLoop(faceId);
    foreach (Curve c in ca)
        var edge = BRepBuilderEdgeGeometry.Create(c);
        BRepBuilderGeometryId edgeId = brepBuilder.AddEdge(edge);
        brepBuilder.AddCoEdge(loopId, edgeId, false);
    brepBuilder.FinishLoop(loopId);
brepBuilder.FinishFace(faceId);
using (var tr = new Transaction(doc, "Create a DirectShape"))
    tr.Start();
    DirectShape ds = DirectShape.CreateElement(doc, new ElementId(BuiltInCategory.OST_GenericModel));
    ds.SetShape(brepBuilder);
    tr.Commit();
Replies (15)
Message 2 of 16
Mohamed_Arshad
Hi @andhxl
   Do you need to project curve over the slab top surface ? Can you please explain in detail
Mohamed Arshad K
Software Developer (CAD & BIM)
Message 3 of 16
jeremy_tammik
Maybe the BRepBuilderExample Revit SDK sample will help?
Message 4 of 16
andhxl
Hi, no, I need to get Solid with one PlanarFace. TessellatedShapeBuilder is not suitable for me, since I need not only Line, but also Arc and so on. Tessellation is not suitable
Message 5 of 16
Mohamed_Arshad
Hi @andhxl
    you need to create solid using one planar face correct ?
Mohamed Arshad K
Message 6 of 16
andhxl
Need Solid consisting of one PlanarFace, created by BRepBuilder.
This is how I get it using TessellatedShapeBuilder. I need the same thing, but without tessellation.
var tsb = new TessellatedShapeBuilder();
tsb.OpenConnectedFaceSet(true);
var facePoints = new List<IList<XYZ>>();
    var points = new List<XYZ>();
        if (c is Line)
            points.Add(c.GetEndPoint(0));
        else
            IList<XYZ> curvePoints = c.Tessellate();
            for (int i = 0; i < curvePoints.Count - 1; i++)
                points.Add(curvePoints[i]);
    facePoints.Add(points);
tsb.AddFace(new TessellatedFace(facePoints, ElementId.InvalidElementId));
tsb.CloseConnectedFaceSet();
tsb.Build();
    tr.Start();
    ds.SetShape(tsb);
    tr.Commit();
Message 7 of 16
Mohamed_Arshad
HI @andhxl
   I understand now, But you have created a TessellatedFace using single planar which a surface not solid. But we can't able to generate solid just using one planar face (Brep). You need thickness for that one. you can do one thing extract complete solid from the slab and and generate feature using DirectShape. Kindy check the below code.
foreach (GeometryObject geoObj in geoElement)
    if (geoObj is Solid)
       solid = geoObj as Solid;
        if (solid.Volume > 0)
            break;
List<GeometryObject> objects = new List<GeometryObject>();
objects.Add(solid);
using (Transaction createGometry = new Transaction(doc, "Create Disconnected Slab"))
    createGometry.Start();
    DirectShape directShape = DirectShape.CreateElement(doc, new ElementId(BuiltInCategory.OST_GenericModel));
    directShape.AppendShape(objects);
    createGometry.Commit();
This is what we can do, Generating Solid using Face it possible, but you have to define some thickness to it.
Hope this will Helps 🙂
Mohamed Arshad K
Message 8 of 16
andhxl
No, that's not what I need. And we can create a Solid with one PlanarFace, I showed this code above with TessellatedShapeBuilder
Message 9 of 16
Mohamed_Arshad
@jeremy_tammik  @naveen.kumar.t @Moustafa_K
Can anyone help in solving this 🙂
Mohamed Arshad K
Message 10 of 16
Mohamed_Arshad
Hi @andhxl
Check the below workaround code
Reference Code
            PlanarFace planarFace = null;
                    Solid solid = geoObj as Solid;
                        FaceArray faceArray = solid.Faces;
                        foreach (Face face in faceArray)
                            if (face is PlanarFace)
                                PlanarFace pFace = face as PlanarFace;
                                if (pFace.FaceNormal.Z == 1)
                                    planarFace = pFace;
                                    break;
using (Transaction createGometry = new Transaction(doc, "Create Surface Highlightes"))
    objects.Add(ConvertPlanarFaceToSolid(planarFace));
 public Solid ConvertPlanarFaceToSolid(PlanarFace planarFace)
     // Get the boundary edges of the planar face
     IList<CurveLoop> curveLoops = planarFace.GetEdgesAsCurveLoops();
     // Get the normal direction of the face
     XYZ normal = planarFace.ComputeNormal(new UV(0.5, 0.5));
     // Set the extrusion height to a very small value, making it a thin BRep
     double extrusionHeight = 0.001;
     // Create a solid by extruding the face along its normal direction
     Solid faceSolid = GeometryCreationUtilities.CreateExtrusionGeometry(curveLoops, normal, extrusionHeight);
     return faceSolid;
Reference Video
Mohamed Arshad K
Message 11 of 16
andhxl
Need PlanarFace without any thickness(
Message 12 of 16
jeremy_tammik
Did you look at the BRepBuilderExample Revit SDK sample, as suggested above? You didn't say anything about that:
It includes a creation of a non-planar face, with no solid.
Please also take a look at the sample code in the documentation:
It demonstrates in detail the creation of faces, edges, coedges, including arcs.
Additional very helpful background information is provided by The Building Coder discussing BRepBuilder organisation:
Message 13 of 16
ricaun
BRepBuilder can be tricky to work with, in your case you should change the BRepType.Solid to BRepType.OpenShell, this basically allow the builder to return a solid without a volume.
Sometimes the orientation matter, specially in the BRepType.Solid and BRepType.Void that you need to make sure all edges is register in the correct orientation.
Pretty sure if you change to BRepType.OpenShell your code gonna work fine.
Here is a full sample to copy a Face to Solid.
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using System;
namespace RevitAddin.Forum.Revit.Commands
    [Transaction(TransactionMode.Manual)]
    public class CommandFaceToSolid : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elementSet)
            UIApplication uiapp = commandData.Application;
            Document document = uiapp.ActiveUIDocument.Document;
            try
                var faceReference = uiapp.ActiveUIDocument.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Face);
                var element = document.GetElement(faceReference);
                var face = element.GetGeometryObjectFromReference(faceReference) as Face;
                var solid = CreateSolidFromFace(face);
                var normal = face.ComputeNormal(new UV(0.5, 0.5));
                using (Transaction transaction = new Transaction(document))
                    transaction.Start("Create Solid");
                    var ds = DirectShape.CreateElement(document, new ElementId(BuiltInCategory.OST_GenericModel));
                    ds.SetName(ds.Category.Name);
                    ds.SetShape(new[] { solid });
                    ds.Location.Move(normal);
                    transaction.Commit();
            catch (Exception ex)
                Console.WriteLine(ex);
            return Result.Succeeded;
        private Solid CreateSolidFromFace(Face face)
            var surface = face.GetSurface();
            var brepBuilder = new BRepBuilder(BRepType.OpenShell);
            var faceIsReversed = !face.OrientationMatchesSurfaceOrientation;
            BRepBuilderGeometryId faceId = brepBuilder.AddFace(BRepBuilderSurfaceGeometry.Create(surface, null), faceIsReversed);
            foreach (CurveLoop curveLoop in face.GetEdgesAsCurveLoops())
                foreach (Curve curve in curveLoop)
                    var edge = BRepBuilderEdgeGeometry.Create(curve);
            brepBuilder.SetFaceMaterialId(faceId, face.MaterialElementId);
            return brepBuilder.GetResult();
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Message 14 of 16
andhxl
I looked, thanks. It became more clear. It especially helped to understand: https://thebuildingcoder.typepad.com/blog/2023/06/brepbuilder-and-toposurface-interior.html#2
Message 15 of 16
andhxl
Thanks, I've tried with BRepType.OpenShell and I got an internal error. If you take the curves from Face, then it really works without problems. But if you get the curves from the slab sketch, then you need to determine whether they are reversed or not. The sketch could have been constructed any way. Now it is clear that it is possible to do this and that is the whole problem. It remains to understand how to accurately determine this
Message 16 of 16
andhxl
Thank you all! In the case of the sketch, I found this way out - combine several actions (creating Face and creating Solid based on it), to not care about the direction of the curves in the sketch:
        var sketch = (Sketch)doc.GetElement(floor.GetSketchId());
        Face face = CreateFaceFromSketch(sketch);
        Solid solid = CreateSolidFromFace(face);
        using (var tr = new Transaction(doc, "Creation DirectShape"))
            tr.Start();
            ds.SetShape([solid]);
            tr.Commit();
    private static PlanarFace CreateFaceFromSketch(Sketch sketch)
        var curveLoops = new List<CurveLoop>();
            var cl = new CurveLoop();
                cl.Append(c);
            curveLoops.Add(cl);
        XYZ dir = sketch.SketchPlane.GetPlane().Normal;
        Solid tempSolid = GeometryCreationUtilities.CreateExtrusionGeometry(curveLoops, dir.Negate(), Application.MinimumThickness);
        return tempSolid.Faces
            .OfType<PlanarFace>()
            .First(f => f.FaceNormal.IsAlmostEqualTo(dir));
    private static Solid CreateSolidFromFace(Face face)
        var surface = BRepBuilderSurfaceGeometry.Create(face.GetSurface(), null);
        bool faceIsReversed = !face.OrientationMatchesSurfaceOrientation;
        BRepBuilderGeometryId faceId = brepBuilder.AddFace(surface, faceIsReversed);
        foreach (CurveLoop cl in face.GetEdgesAsCurveLoops())
            foreach (Curve c in cl)
                BRepBuilderGeometryId edgeId = brepBuilder.AddEdge(BRepBuilderEdgeGeometry.Create(c));
Although, perhaps this can be done by creating a CurveLoop and determining the direction using IsCounterclockwise, without creating a temporary Solid
