Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Creating rooms from space
jeroen.vanvlierden
jeroen.vanvlierden
I have a command that creates a room from a given space
When i set the room.LimitOffset = space.LimitOffset; I get an exception
even when i do in the debugger:  space.LimitOffset = space.LimitOffset;  I get the same exception
when I set it to an integer value it works, but setting it to any kind of double precision value raises this weird exception.
jeroen.vanvlierden
And this workaround seems to work
jeremy_tammik
Interesting.
What exactly does your source code look like that produces this exception?
Can you produce a minimal reproducible case, optimally a macro in a model containing one single space?
https://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Regarding your workaround:
  • Do you have to go via the string representation of the parameter value?
  • What happens if you read or set the double value?
jeroen.vanvlierden
Hi Jeremy,
Thanks for looking into this
to reproduce this: create a space with a LimitOffset of 2700.0 in mm =>  8.85826772 feet and copy and paste the C# code in an ExternalCommand class
run this and you will see that I
- can copy and set the double value as a parameter
- can copy and set the string value as a parameter
- can not set the class property, I get the following exception message
{"Enter a value or a formula starting with \"=\"."}
using System.Collections.Generic;
using System.Linq;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.UI;
using View = Autodesk.Revit.DB.View;
namespace Test
[Transaction(TransactionMode.Manual)]
class TestCommand : IExternalCommand
private UIDocument _uiDocument;
private Document _document;
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
_uiDocument = commandData.Application.ActiveUIDocument;
_document = _uiDocument.Document;
Transaction transaction = new Transaction(_document, "testcommand");
transaction.Start();
var spaces = GetSpacesInActiveView(_uiDocument.ActiveView);
foreach (var space in spaces)
CreateRoomFromSpace(space);
transaction.Commit();
return Result.Succeeded;
private void CreateRoomFromSpace(Space space)
var locationPoint = (space.Location as LocationPoint)?.Point;
if (locationPoint == null) return;
var room = _document.Create.NewRoom(space.Level, new UV(locationPoint.X, locationPoint.Y));
room.UpperLimit = space.UpperLimit;
//works
var doubleValue = space.LookupParameter("Limit Offset").AsDouble();
room.LookupParameter("Limit Offset").Set(doubleValue);
//works
var stringValue = space.LookupParameter("Limit Offset").AsValueString();
room.LookupParameter("Limit Offset").SetValueString(stringValue);
//raises weird exception
room.BaseOffset = space.BaseOffset;
room.Name = space.Name;
room.Number = space.Number;
private IEnumerable<Space> GetSpacesInActiveView(View activeView)
var getSpacesInActiveView = new FilteredElementCollector(_document, activeView.Id)
.OfClass(typeof(SpatialElement))
.WhereElementIsNotElementType()
.Where(e => e is Space && e.Location != null)
.Cast<Space>()
.Where(r => r.Area > 0)
.ToList();
return getSpacesInActiveView;
