Creating Revit Pluings with "Visual Studio Code" instead of "Visual Studio"
To create Revit Add-in, I checked Jeremy's Revit Visual Studio Templates below.
https://github.com/jeremytammik/VisualStudioRevitAddinWizard
I am wondering if there is any way I could use those templates to create Revit plugins using Visual Studio Code instead?
Any advice will be much appreciated.
Many thanks,
Alexandros
jeremytammik
I do not believe that Visual Studio Code supports those templates.
You will have to use a different approach to jump start your Revit add-ins in Visual Studio code, e.g., using code snippets, etc.:
https://code.visualstudio.com/docs/editor/userdefinedsnippets
Jeremy Tammik
Developer Technical Services
The Building Coder
atis.sed
Hi @Anonymous did you manage to make Revit plugin with VS Code? I would like to also switch from VS to VSCode.
