Creating Reference Plane to put bubbles in it's line
diogo.vieiraBCKUL
Message 1 of 10
diogo.vieiraBCKUL
I would like to know if it is possible to create a Reference Plane and then, put all the bubbles that intersect it, in its line.
Following an image of what i mean:
Moving those bubbles to the created Reference Plane. Could anyone help?
Replies (9)
Message 2 of 10
jeremy_tammik
The reference plane seems to be vertical to the view you display. So, when you say, move the bubble to the ref plane, do you in fact mean, move the bubble to the intersection line between the ref plane and the view plane?
Message 3 of 10
diogo.vieiraBCKUL
Do something like this:
The bubbles moved to the created Reference Plane.
Message 4 of 10
jeremy_tammik
Have you searched this forum for the term 'bubble'? I just did and see several promising-looking hits.
Message 5 of 10
diogo.vieiraBCKUL
Yah i did. But i don't tink there is anything that I can use to move them into the Reference Plane.
Message 6 of 10
jeremy_tammik
Do you really mean 'move them to the ref plane, and not move them to the intersection ref plane - view? Isn't the ref plane perpendicular to the view? Sorry for my stupid question, I am not a product user and have no idea what you are trying to achieve.
Message 7 of 10
diogo.vieiraBCKUL
I am also sorry. Probably am not explaining myself correctly. Basically, what I am trying to achieve is when the user clicks in the bubble, the bubles moves into that Reference Plane or intersection.
Message 8 of 10
AGGilliam
Assuming you're trying to move the bubbles to align to the curve of the reference plane in that view and not on the plane itself, you could use the GetCurvesInView method to retrieve the curve of your reference plane and then move the bubbles to their respective intersection points.
Message 9 of 10
diogo.vieiraBCKUL
That sounds like a good idea! But how do I get to move the bubbles?
Message 10 of 10
AGGilliam
@jeremy_tammik  actually posted an example that explains how to move grid endpoints here. All you need to do is determine which end point has the bubble.
