Creating Plugin in Revit Server
111Auto302
111Auto302
We have a requirement to create a plugin in Revit server which will automate some process. Is there any way to create a plugin in the Revit Server ?
If yes how can we do it.
matthew_taylor
There is a section of the SDK dedicated to the Revit Server.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
111Auto302
In the SDK we could not find any solution for the plugin creation.
matthew_taylor
Hi @111Auto302,
You cannot have looked very hard! Smiley Wink
There's a sub-folder called 'Revit Server SDK'. There is a single (zipped) example and a couple of documents there.
Cheers,
-Matt
