Creating plates using excel info
pedro_mejia
pedro_mejia
I need to create a ton of plainer plate in revit I have all the coordinates need to create each plate in an excel I just need to know if there is a way to script this in Revit. FYI they are not similar plates each has a different shape imagine a star with flat points and each point changes. In AutoCad I could have drop the points and connected the dots with a lines then extruded the shape in a script can I do that in sketch mode inside of Revit. any help would be appreciated. Thanks
jeremytammik
Dear Pedro,
Thank you for your query.
This should be perfectly doable.
I see two feasible approaches.
You can either create a family instance for each plate, which is possible but rather convoluted and inefficient, or use a more efficient approach based on DirectShape elements.
It really depends on a number of other circumstances, your workflow, scheduling requirements etc.
If all you care about is just generating the plate shapes, I would suggest using DirectShape elements.
Here is all you need to know on that topic:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.50
I hope this helps.
Please let us know how you end up solving this.
Thank you!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
