Creating New Macros
Creating New Macros
Creating New Macros
Hello, I just started using Autodesk Revit 2014 and I wanted to create some Macro.
I looked up some tutorials on the intenet and learned that when I try to create a new Macro, a SDA or VSTA window should pop-up so I can write my code.
The problem is when I try to create my Macro, nothing happens. No window pop-up and I´m unable to write the code.
I have installed MS Visual Studio Express and Revit SDK, and doesnt matter what language I try to use, it is always the same.
Does anyone knows if I missed any required programs for this to work, or if there might be some bug with Revit?
Thanks.
mikako_harada
Hi Thiago,
Macro environment comes with the product. You don't need to install a separate visual studio environment. Please follow the instruction in the product help:
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-F0A122E0-E556-4D0D-9D0F-7E72A9315A42
Revit Users >> Customize Revit >> Automating tasks with Macros.
If your Does not start A macro environment from the macro button, then you have a problem with the installation itself. Please ask the product support about it.
Mikako Harada
Developer Technical Services
