Hello ,
My name is Amr from Cairo, Egypt. I'm an Architecture Student at the Bachelor's Final Year and I'm an Autodesk Revit User.
Currently I'm working on a series of AddIns to the Revit API to Automate some Processes trying to cut down the time and effort required to accomplish my work and this is my first participation here, I'm posting here after 10 hrs trying to solve the problem by myself in many ways, so I'm hoping that I can find the answer here by the experts.
I'm currently working on a plugin that creates all project floors by iterating through all rooms defined in the project and use their boundaries as profiles for the newly generated floors, but it keeps giving me the error in the msg as shown in the image, I attached the MainProgramCode.cs, any help is really appreciated
Thanks and Kind Regards ,
Amr,
namespace GenerateFloorByRoom { public class FloorData { List<Room> projectRooms = new List<Room>(); // a list to store all rooms in the project private Hashtable floorTypes; private List<string> floorTypesName; private FloorType floorType; private Level level; private CurveArray profile; private bool structural; private const double PRECISION = 0.00000001; private Autodesk.Revit.Creation.Application creApp; private Document document; // a floor type to be used by the new floor instead of the default type public FloorType FloorType { get { return floorType; } set { floorType = value; } } // the Level on which the floors are to be placed public Level Level { get { return level; } set { level = value; } } // an array of planar lines and arcs that represent the horizontal profile of the floor public CurveArray Profile { get { return profile; } set { profile = value; } } // determine wether the floor is structural public bool Structural { get { return structural; } set { structural = value; } } // a list of all Floor Types Name that could be used by the new Floor public List<string> FloorTypesName { get { return floorTypesName; } set { floorTypesName = value; } } public List<Room> GetAllRooms() { // get the Active Document document =Command.uiApp.ActiveUIDocument.Document; RoomFilter roomFilter = new RoomFilter(); FilteredElementIdIterator roomIter = (new FilteredElementCollector(document)).WherePasses(roomFilter).GetElementIdIterator(); roomIter.Reset(); // try to find all the Rooms in the Project and add it to the List while (roomIter.MoveNext()) { object obj = roomIter.Current; // find all Rooms on Condition IsLocatedOnLevel Room tmpRoom = obj as Room; if (null != tmpRoom && null != document.GetElement(tmpRoom.LevelId)) { projectRooms.Add(tmpRoom); continue; } } return projectRooms; } // obtain all Data which is necessary for floor generation public void ObtainData(ExternalCommandData commandData) { if (null == commandData) { throw new ArgumentNullException("commandData"); } UIDocument doc = commandData.Application.ActiveUIDocument; document = doc.Document; List<Room> rl = new List<Room>(GetAllRooms()); creApp = commandData.Application.Application.Create; Profile = creApp.NewCurveArray(); FilteredElementIterator iter = (new FilteredElementCollector(doc.Document)).OfClass(typeof(FloorType)).GetElementIterator(); ObtainFloorTypes(iter); foreach (Element elem in rl) { Transaction tran = new Transaction(document, "ElementBatchCreation"); tran.Start(); ObtainProfile(rl); ObtainLevel(rl); document.Regenerate(); tran.Commit(); } Structural = true; } // obtain all types that are avilable for floor types in the current document private void ObtainFloorTypes(FilteredElementIterator elements) { floorTypes = new Hashtable(); FloorTypesName = new List<string>(); elements.Reset(); while (elements.MoveNext()) { Autodesk.Revit.DB.FloorType ft = elements.Current as Autodesk.Revit.DB.FloorType; if (null == ft || null == ft.Category || !ft.Category.Name.Equals("Floors")) { continue; } floorTypes.Add(ft.Name, ft); FloorTypesName.Add(ft.Name); FloorType = ft; } } public void ChooseFloorType(string typeName) { FloorType = floorTypes[typeName] as FloorType; } private void ObtainLevel(List<Room> rooms) { Autodesk.Revit.DB.Level temp = null; foreach (Room r in rooms) { if (null == temp) { temp = document.GetElement(r.LevelId) as Level; Level = temp; } } } // obtain floor profile from each room's boundary private void ObtainProfile(List<Room> rooms) { foreach (Room r in rooms) { Level l = (r.Level); SketchPlane.Create(document, l.LevelId); SpatialElementBoundaryOptions bo = new SpatialElementBoundaryOptions(); IList<IList<BoundarySegment>> segments = r.GetBoundarySegments(bo); if (null != segments) // the Room may not be bound { foreach (IList<Autodesk.Revit.DB.BoundarySegment> segmentList in segments) { CurveArray temp = new CurveArray(); foreach (Autodesk.Revit.DB.BoundarySegment boundarySegment in segmentList) { Curve c = boundarySegment.GetCurve(); temp.Append(c); } SortCurves(temp); } } } } private void SortCurves(CurveArray lines) { Autodesk.Revit.DB.XYZ temp = lines.get_Item(0).GetEndPoint(1); Curve temCurve = lines.get_Item(0); Profile.Append(temCurve); while (Profile.Size != lines.Size) { temCurve = GetNext(lines, temp, temCurve); if (Math.Abs(temp.X - temCurve.GetEndPoint(0).X) < PRECISION && Math.Abs(temp.Y - temCurve.GetEndPoint(0).Y) < PRECISION) { temp = temCurve.GetEndPoint(1); } else { temp = temCurve.GetEndPoint(0); } Profile.Append(temCurve); } } private Curve GetNext(CurveArray profile, Autodesk.Revit.DB.XYZ connected, Curve line) { foreach (Curve c in profile) { if (c.Equals(line)) { continue; } if ((Math.Abs(c.GetEndPoint(0).X - line.GetEndPoint(1).X) < PRECISION && Math.Abs(c.GetEndPoint(0).Y - line.GetEndPoint(1).Y) < PRECISION && Math.Abs(c.GetEndPoint(0).Z - line.GetEndPoint(1).Z) < PRECISION) && (Math.Abs(c.GetEndPoint(1).X - line.GetEndPoint(0).X) < PRECISION && Math.Abs(c.GetEndPoint(1).Y - line.GetEndPoint(0).Y) < PRECISION && Math.Abs(c.GetEndPoint(1).Z - line.GetEndPoint(0).Z) < PRECISION) && 2 != profile.Size) { continue; } if (Math.Abs(c.GetEndPoint(0).X - connected.X) < PRECISION && Math.Abs(c.GetEndPoint(0).Y - connected.Y) < PRECISION && Math.Abs(c.GetEndPoint(0).Z - connected.Z) < PRECISION) { return c; } else if (Math.Abs(c.GetEndPoint(1).X - connected.X) < PRECISION && Math.Abs(c.GetEndPoint(1).Y - connected.Y) < PRECISION && Math.Abs(c.GetEndPoint(1).Z - connected.Z) < PRECISION) { if (c.GetType().Name.Equals("Line")) { Autodesk.Revit.DB.XYZ start = c.GetEndPoint(1); Autodesk.Revit.DB.XYZ end = c.GetEndPoint(0); return Line.CreateBound(start, end); } else if (c.GetType().Name.Equals("Arc")) { int size = c.Tessellate().Count; Autodesk.Revit.DB.XYZ start = c.Tessellate()[0]; Autodesk.Revit.DB.XYZ middle = c.Tessellate()[size / 2]; Autodesk.Revit.DB.XYZ end = c.Tessellate()[size]; return Arc.Create(start, end, middle); } } } throw new InvalidOperationException("The Room Boundary should be closed."); } } }
