Creating custom dockable pan/window for showing real-time sensor data
mostafa.hallaji
mostafa.hallaji
Dear all,
I hope my message finds you well,
I want to create a custom dockable pan/window for my Revit model, using Revit API. I am wondering if we can perform this task by Dynamo or Python? If yes, what are the best sources/articles/videos that I can refer to learn this task. If no, I am aware that I need to use C# to communicate directly with the Revit API, again what sources do you suggest me to start from the scratch.
Your advice is highly appreciated.
Kind regards,
Mostafa.
jeremy_tammik
Dear Mostafa,
Welcome to the Revit API.
I would suggest that you study the getting started material first to gather an understanding of the fundamentals and architecture:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#2
The Revit API is purely .NET based. You can use any language that connects to the .NET environment, including Python. It is not limited to C#.
That said, many of the samples are provided in C#.
Here are discussions of some aspects of dockable panels:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.4
mostafa.hallaji
Hi Jeremy,
Thanks for your constructive suggestion (as always!) and providing the links. I think the C# approach is a more promising way to go, since there are good number of examples available on the net and it would be fun to get familiar with a new programming language!
Kind regards,
Mostafa.
jeremy_tammik
Dear Mostafa,
Thank you for you kind words and thoughtful ideas. Yes, sounds great. Looking forward to hearing how it goes for you. Good luck!
Cheers,
Jeremy
