Creating an IFC with a Level 1 Included
David_Robison
David_Robison
Following up on this post:
https://forums.autodesk.com/t5/revit-api/ifc-import-level-line-is-automatically-created/m-p/6216561#...
What does an IFC file need to contain for Revit to see it as having a "Level 1"?
I exported and imported a simple IFC file using Revit (see attached). It has the same problem the IFC file I created has. A new "Level 1" at elevation 0m is created.
jeremytammik
Dear David,
Thank you for your query and sample IFC file.
Sorry that I missed your update to the original thread.
The resolution suggested in the original thread was summarised by The Building Coder:
http://thebuildingcoder.typepad.com/blog/2016/02/ifc-import-levels-and-mep-element-shapes.html#2
Sorry that it does not work right out of the box.
I am passing on your query and sample file to the development team who made the suggestion in the first place.
Let's see what they reply this time.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
