Creating A Roof Using Revit APIs
aniket_pachore
Message 1 of 21
aniket_pachore
I am facing an issue while creating a roof using C# Revit APIs.
              I am automating the conversion of 2D AutoCAD drawings to Revit 3D models. The process involves reading data from AutoCAD drawings. I store the polylines (on which I want to create the roof) in a list, specifically List<PolyLine> roofPolyLineList, and pass it to my function. First, I convert the polyline into a CurveArray, CurveArray topFloorCurveArray = application.Create.NewCurveArray(), and pass it to the API. I am not getting any errors, but the roof is not created in Revit.
I have attached my code below.
Please help me to solve the issue.
private void CreateRoof(Document doc, List<Level> floorlevels, List<PolyLine> roofPolyLineList)
            Application application = doc.Application;
            CurveArray topFloorCurveArray = application.Create.NewCurveArray();
            RoofType roofType= new FilteredElementCollector(doc).OfClass(typeof(RoofType)).FirstOrDefault<Element>() as RoofType;
            Transaction trans = new Transaction(doc, "Create Roof");
            trans.Start();
                for (int i = 0; i < roofPolyLineList.Count; ++i)
                    var points = roofPolyLineList[i].GetCoordinates();
                    for (int j = 0; j < points.Count - 1; j++)
                        var start = points[j];
                        var end = points[j + 1];
                        var line = Line.CreateBound(new XYZ(start.X, start.Y, start.Z), new XYZ(end.X, end.Y, end.Z));
                        topFloorCurveArray.Append(line);
                for (int i = 0; i < floorlevels.Count; i++)
                    int count = floorlevels.Count;
                    string name = "Floor " + (count - 1);
                    Level level = floorlevels[i];
                    if (level.Name == name)
                        ModelCurveArray footPrintToModelCurveMapping = new ModelCurveArray();
                        FootPrintRoof footprintRoof = doc.Create.NewFootPrintRoof(topFloorCurveArray, level, roofType, out footPrintToModelCurveMapping);
                        ModelCurveArrayIterator iterator = footPrintToModelCurveMapping.ForwardIterator();
                        iterator.Reset();
                        while (iterator.MoveNext())
                            ModelCurve modelCurve = iterator.Current as ModelCurve;
                            footprintRoof.set_DefinesSlope(modelCurve, true);
                            footprintRoof.set_SlopeAngle(modelCurve, 0.5);
                doc.Regenerate();
                trans.Commit();
Replies (20)
Message 2 of 21
Moustafa_K
I see your code is fine. Are you sure the level name matches your specifics, specifically at this part of the code
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
Message 3 of 21
admaecc211151
A simple way is to show Messages or write log into a log file
to check where your code is running to there or not.
I thought you can replace
into
floorlevels = floorlevels.OrderBy(i => i.Elevation).ToList();
Level level = floorlevels[floorlevels.Count -1];
Since you only want to create the roof in top level.
//or maybe not send a list, just a level into this function is better.
Message 4 of 21
aniket_pachore
Yes, the condition is fine; my pointer goes into the 'if' condition. The 'Level Name' matches the 'Expected Level Name'. The code in the 'if' condition also gets executed, but the roof doesn't get created.
My Question : Whether the API works for only wall selection, or it also takes the CurveArray (Closed Loop PolyLines) ?
Please help @admaecc211151@Moustafa_K
Message 5 of 21
Moustafa_K
Surely it has to be closed loop. Try testing your method by supplying rectangle points. It should be 5 points to close the loop.
Moustafa Khalil
Message 6 of 21
aniket_pachore
Ok Sure, I will try and get back to you. Thank you.
Message 7 of 21
aniket_pachore
Hello @Moustafa_K,
I tried using a simple rectangle, but it still isn't working. I also checked that the lines I am adding to the CurveArray 'topFloorCurveArray' are appended in order and form a closed loop. Yes, they are in order and forms a closed loop.
@Moustafa_K
Message 8 of 21
jeremy_tammik
Have you looked at the Revit SDK NewRoof sample? It includes a call to set_DefinesSlope. Maybe that will give you some hints.
Message 9 of 21
scgq425
hi @aniket_pachore : i saw u code is fine , in u rvt template the pashe is archite or all , may be u create it but the target view hidden it . u can open u filter to set this .
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
Message 10 of 21
aniket_pachore
Hi @scgq425 ,
                        I didn't get what you want to suggest me, you mean I have to open the project in "Architectural Template". yes I tried in "Architectural Template" also but it still not reflecting.
Message 11 of 21
Charles.Piro
Hi @aniket_pachore,
in my view, your problem is in inside this loop :
At the end, the last Curve is missed.
With this loop, your code is functional :
for (int j = 0; j < points.Count; j++)
   var end = new XYZ();
   if (j + 1 == points.Count)
      end = points[0];
   else
PIRO Charles
Developer
PIRO CIE
Linkedin
Message 12 of 21
aniket_pachore
Hi @Charles.Piro ,
                                As I am trying for a simple rectangle input, I get total 5 point to close my loop. The loop was also closing using my previous code. I also tried using your code. You can see I get total 5 points from my Polyline, And it is creating four curves as I see while debugging. Still same problem I am Facing.
I have made small change in your code .
Previous for Loop,
Changed for Loop,
Because of 5 Points.
Message 13 of 21
Moustafa_K
Just a simple 5 points, no need for for loop, I just tested your code and seems fine with the five points. it looks like your inputs are not correct, could be a level or polyline
CreateRoof(Doc, aLevel.Id, new List<PolyLine>
     PolyLine.Create([XYZ.Zero,new XYZ(10,0,0), new XYZ(10,5,0 ),new  XYZ(0,5,0),XYZ.Zero])
Moustafa Khalil
Message 14 of 21
Charles.Piro
I have tried it with your data and it works fine for me.
I just removed the level name test.
PIRO Charles
Developer
PIRO CIE
Linkedin
Message 15 of 21
aniket_pachore
Hi @Charles.Piro
Everything looks fine to me: the level, the closed loop curve, etc.
I have a question: Is there a chance that elements are hidden by default?
                                  If so, how can I unhide them using programming?
Because from your side, you can see the roof, but from my side, I can't.
I am new to Revit, so your answer would be very helpful for me.
Message 16 of 21
aniket_pachore
Hi @Moustafa_K ,
                              I didn't get it, How could I directly Pass the polyline.
Message 17 of 21
admaecc211151
I would check and fix every point in the polyline.
Check that the end of line n-1 is same to the start of line n.
Or just replace all the start of line n to the same point as end of line n-1.
Sometimes the points work good in Revit and Cad (the distance is 0.00(several zeros)001).
But too large for C# API.
Message 18 of 21
aniket_pachore
@admaecc211151
Ok Sure, I will try and let you know. Thank you
Message 19 of 21
aniket_pachore
Hi @admaecc211151 ,
Yes, I did it what you suggested. I replaced the endPoint of previous curve with startPoint of current Curve, but still not working.
I didn't get any type of error, and I cant see the roof.
Message 20 of 21
aniket_pachore
Thanks a lot, @Moustafa_K, @Charles.Piro, @scgq425, @admaecc211151.
I was making a silly mistake. The problem was that I was using the default roof type, which was transparent, so I couldn't see it. I just chose another type, and the job is done.
