creating a new pipe segment
Hi, in the old C# API there was a function a function : Autodesk.Revit.DB.Plumbing.Pipe Autodesk.Revit.Creation.Document.NewPipe(XYZ, Connector, PipeType) but this has been removed from the 2016 API. Possibly by something less logical and transparent. Can someone please teel me how to create new paramterized pipe segments in an empty document?
eric_grey
Try using this:
Autodesk.Revit.DB.Plumbing.Pipe.Create(…)
Eric
Eric Grey
Software QA Analyst
Thank you for your help Eric. Can you tell me what is the best way to get started in understanding Revit/the SDK? I did the quick tutorial but that is very low level ('what is programming' introduction). Should I understand Families first or sth?
eric_grey
You will probably want to look at the SDK samples from here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2484975
Hope that helps,
Eric
Eric Grey
Software QA Analyst
