Creates a new duct from two points with revit 2019 api
congvietbk
congvietbk
Hi everyone,
I have a little problem. I could not get the systemTypeId to create the wind pipe from 2 points (XYZ) with a new project. I use the function following:
public static Duct Create(
	Document document,
	ElementId systemTypeId,
	ElementId ductTypeId,
	ElementId levelId,
	XYZ startPoint,
	XYZ endPoint
In the 2016 revit version I used the a function very easily but i can't found this function in above Revit 2017 version.
public Duct NewDuct(
	XYZ point1,
	XYZ point2,
	DuctType ductType
Please help me. Thank you.
Best regards
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @congvietbk ,
try using the below code
MEPSystemType mepSystemType = new FilteredElementCollector(doc)
        .OfClass(typeof(MEPSystemType))
        .Cast<MEPSystemType>()
        .FirstOrDefault(sysType => sysType.SystemClassification == MEPSystemClassification.SupplyAir);
MEPSystemClassification classify MEP connectors and systems and drives certain behavior for a particular system type
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
congvietbk
Autodesk.Revit.DB.Mechanical.DuctType ductType = GetDuctType();
ElementId levelId=GetLevelId();
XYZ startPoint = new XYZ();
XYZ endPoint = new XYZ(100, 100,0);
var mecSystem = new FilteredElementCollector(doc)
.OfClass(typeof(MEPSystem))
.Cast<MEPSystem>()
.FirstOrDefault(sysType => sysType.GetType() == typeof(MechanicalSystem));
ElementId systemTypeId = mecSystem.GetTypeId();
Duct duct = Duct.Create(doc,systemTypeId, ductType.Id,levelId,startPoint,endPoint);
in the project if I have not set the equipment, air terminals, ducts then mecSystem = null
Is there a way to still create a duct with the Duct.Create function without having to draw the duct first in the revit?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @congvietbk ,
Yes, it is possible to create a duct with the Duct.Create() without having to draw the duct first in the Revit.
Here is the complete code to draw a duct in Revit using Revit API
Level L;
                FilteredElementCollector collector = new FilteredElementCollector(doc).OfClass(typeof(DuctType)).WhereElementIsElementType();
                DuctType DT = collector.First() as DuctType;
                Duct duct = Duct.Create(doc,mepSystemType.Id ,DT.Id, L.Id,new XYZ(0, 0, 0), new XYZ(100, 100, 0));
If you still have any questions...can you please explain briefly?
Please note:sys.SystemClassification and sys.GetType() are doing different operations here.
Here we are filtering duct type and duct system type from the project not from the placed elements.
Naveen Kumar T
I'm having a similar problem, and when I try to use this method for finding the SystemTypeId I get an error from Revit that says, "The systemTypeId is not a valid HVAC system type". Does anyone know how to fix this error?
Not sure how to delete this.. but I solved this.
