Create Wall using Curves
NonicaTeam
Message 1 of 8
NonicaTeam
I am trying to create a wall with a list of curves using the overload in IronPython:
public static Wall Create(
	Document document,
	IList<Curve> profile,
	ElementId wallTypeId,
	ElementId levelId,
	bool structural
What I do is I get the lines, ordered them sequentially and create the wall. With a rectangular wall, it does work well. The issue is when adding a hole in the profile curves. I cannot stop getting Failed to create wall error. I tried all sorts (reordering the other way around) of workarounds but nothing seems to work.
This is the method I use to order the lines before calling the wall creation (all lines are cloned before trying to create the new wall and comes from the edges of an actual wall):
def foundFollowingCurve(self, sel_crv, outer_crvs, array_curves, skip_ind):
		try:
			st_po  = sel_crv.GetEndPoint(0)
			end_po = sel_crv.GetEndPoint(1)
			for ind, out_crv in enumerate(outer_crvs):
				if not ind in skip_ind:
					at_st_po  = out_crv.GetEndPoint(0)
					at_end_po = out_crv.GetEndPoint(1)
					if (end_po.IsAlmostEqualTo(at_st_po) or st_po.IsAlmostEqualTo(at_st_po)):
						skip_ind.Add(ind)
						array_curves.Add(out_crv)
						return self.foundFollowingCurve(out_crv, outer_crvs, array_curves, skip_ind)
					elif (end_po.IsAlmostEqualTo(at_end_po) or st_po.IsAlmostEqualTo(at_end_po)):
						skip_ind.Add(ind)
						array_curves.Add(out_crv.CreateReversed())
			return array_curves, skip_ind
		except Exception as e:
			Autodesk.Revit.UI.TaskDialog.Show("Exception", str(e) + " - " + str(sys.exc_info()[-1].tb_lineno))
Anyone had experience this issue before?
Replies (7)
Message 2 of 8
scgq425
Hi @NonicaTeam :
this api paramter : IList Curves is the vertical profile not the wall location path , if you want  to create a rectangular boundary wall , you can use this
`Create Method (Document, Curve, ElementId, Boolean)` or `Create Method (Document, Curve, ElementId, ElementId, Double, Double, Boolean, Boolean)` and loop you path list.
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
Message 3 of 8
NonicaTeam
I appreciate the comment.
I am feeding in the profile curves.
Message 4 of 8
scgq425
Hi @NonicaTeam :
im sry to post a wrong answer .
if you want to add a hole use api , the wall profile direction and the hole path direction list need all clockwise or reclockwise , like the list :
public List<Curve> CreateWallBoundaryList()
XYZ p1 = new XYZ(0, 0, 0);
XYZ p2 = new XYZ(5, 0, 0);
XYZ p3 = new XYZ(5, 0, 10);
XYZ p4 = new XYZ(0, 0, 10);
XYZ p5 = new XYZ(1, 0, 2);
XYZ p6 = new XYZ(3, 0, 2);
XYZ p7 = new XYZ(3, 0, 5);
XYZ p8 = new XYZ(1, 0, 5);
Line l1 = Line.CreateBound(p1, p2);
Line l2 = Line.CreateBound(p2, p3);
Line l3 = Line.CreateBound(p3, p4);
Line l4 = Line.CreateBound(p4, p1);
Line l5 = Line.CreateBound(p5, p6);
Line l6 = Line.CreateBound(p6, p7);
Line l7 = Line.CreateBound(p7, p8);
Line l8 = Line.CreateBound(p8, p5);
List<Curve> curves = new List<Curve>()
l1,
l2,
l3,
l4,
l5,
l6,
l7,
l8
return curves;
LanHui Xu 徐兰辉
Blog
LinkedIn
Message 5 of 8
NonicaTeam
Thanks for your message and the details.
I made sure the edges and the hole lines were anticlockwise, however, I keep getting Failed to create wall.
Attached the coordinate list and wall picture.
Message 6 of 8
scgq425
Hi @NonicaTeam :
you coordinate is right , but in this api has a bug is : the boundary profile 's first line cant vertical to the inner profile 's first line , is a hidden bug .
so i change you inner list locate like this code , if you code auto sort list , you can add a funciton to make this start coordinate to next : (
XYZ p1 = new XYZ(49, -60, 30);
XYZ p2 = new XYZ(36, -60, 30);
XYZ p3 = new XYZ(36, -60, 0);
XYZ p4 = new XYZ(49, -60, 0);
XYZ p5 = new XYZ(44, -60, 15.4);
XYZ p6 = new XYZ(40, -60, 15.4);
XYZ p7 = new XYZ(40, -60, 10.2);
XYZ p8 = new XYZ(44, -60, 9.2);
// old locate
//XYZ p5 = new XYZ(44, -60, 9.2);
//XYZ p6 = new XYZ(44, -60, 15.4);
//XYZ p7 = new XYZ(40, -60, 15.4);
//XYZ p8 = new XYZ(40, -60, 10.2);
l1,
l2,
l3,
l4,
l5,
l6,
l7,
l8
return curves;
LanHui Xu 徐兰辉
Blog
LinkedIn
Message 7 of 8
NonicaTeam
Thanks. I appreciate your help.
I wish this was more documented. This can get complex when you have arcs instead of lines and so on.
Message 8 of 8
scgq425
Hi @NonicaTeam :
this error likely the revit to calcute two face normal-direction and get difference this  . but no public solution to solve this : (
LanHui Xu 徐兰辉
Blog
LinkedIn
