Create views and group them together in tabs
lutz.kaiser
Observer Observer
lutz.kaiser
Observer
Observer
Hi there!
I want to use a macro to open specific views. Let's
say the start view is Level 0 and I want to open Level 1 in a new tab
and add Level 2 to this newly created tab. At the end I should have two tabs: Tab 1
with Level 0 View and tab 2 with the views of Level 1 + 2.
But there is nothing like:
View.open( new_tab = false, add_to_tabgroup = tab_nbr, *args)
in the UIDocument, in the Document or in the UIApp - so how can I do this?
In the next step the size of the view-window should be changed (not of the zoom).
Thanks!
lutz.kaiser
Observer
Observer
I got somewhat forward.
Activating Views is through uiDoc.RequestViewChange(view) 😅
But the grouping of the tabs, especially the grouping and resizing of tabs is just a workaround, because I wanted to restore the last active session with all the viewwindow position and sizes. Now it's more a template for activating the views.
However, here is what I have done so far:
# First Macro
1. Create a List with the Names of the views I first want to open
2. Create a Dict with the above viewnames as keys and the viewnames I want to open in the same tab as values
3. Open the views from 1. and tile them through the postableCommand
# Second Macro
4. Iterate over all views, activate those from 1. again and by that I open the views which names stored as values in the Dict.
Because the postableCommand is not excecuted until Revit gets the control back from Macro, I need those two macros.
