Create Spline from multiple line, curve, arc segments
dwightduronidavy
dwightduronidavy
Dear all,
I am currently working on the below Revit 2024 macro which does the following:
1. prompt user to select multiple lines and or curve and or arcs
2. convert combined segments into a Spline
However, it keeps generating the following error:
No overload for method 'Create' takes 2 arguments (CS1501) - C:\ProgramData\Autodesk\Revit\Macros\2024\Revit\AppHookup\CreateSplineFromMultipleSegments\Source\CreateSplineFromMultipleSegments\ThisApplication.cs:74,41
Any help would be very much appreciated.
MACRO:
using System;
using System.Collections.Generic;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
namespace CreateSplineFromMultipleSegments
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
[Autodesk.Revit.DB.Macros.AddInId("055979FA-2219-4A0B-A529-E8C0885531D5")]
public partial class ThisApplication
private void Module_Startup(object sender, EventArgs e) { }
private void Module_Shutdown(object sender, EventArgs e) { }
#region Revit Macros generated code
private void InternalStartup()
this.Startup += new System.EventHandler(Module_Startup);
this.Shutdown += new System.EventHandler(Module_Shutdown);
#endregion
public void CreateSpline()
UIDocument uidoc = this.ActiveUIDocument;
Document doc = uidoc.Document;
Selection sel = uidoc.Selection;
try
// Prompt user to select multiple elements
IList<Reference> selectedElements = sel.PickObjects(ObjectType.Element, "Select multiple segments (lines, arcs, splines).");
if (selectedElements == null || selectedElements.Count == 0)
TaskDialog.Show("Error", "No elements selected.");
return;
// Collect all the points from the selected elements
List<XYZ> points = new List<XYZ>();
foreach (Reference reference in selectedElements)
Element element = doc.GetElement(reference);
LocationCurve locationCurve = element.Location as LocationCurve;
if (locationCurve != null)
Curve curve = locationCurve.Curve;
if (curve != null)
points.Add(curve.GetEndPoint(0));
points.Add(curve.GetEndPoint(1));
// Ensure unique points and maintain order
points = RemoveDuplicatePoints(points);
if (points.Count < 2)
TaskDialog.Show("Error", "Not enough points to create a spline. At least two unique points are required.");
return;
// Create the spline from the collected points
using (Transaction tx = new Transaction(doc, "Create Spline"))
tx.Start();
NurbSpline spline = NurbSpline.Create(points, false);
SketchPlane sketchPlane = SketchPlane.Create(doc, Plane.CreateByNormalAndOrigin(XYZ.BasisZ, XYZ.Zero));
ModelCurve modelCurve = doc.Create.NewModelCurve(spline, sketchPlane);
tx.Commit();
TaskDialog.Show("Success", String.Format("Spline created successfully from {0} segments.", selectedElements.Count));
catch (Autodesk.Revit.Exceptions.OperationCanceledException)
TaskDialog.Show("Cancelled", "Operation cancelled by the user.");
catch (Exception ex)
TaskDialog.Show("Error", String.Format("An error occurred: {0}", ex.Message));
private List<XYZ> RemoveDuplicatePoints(List<XYZ> points)
List<XYZ> uniquePoints = new List<XYZ>();
foreach (XYZ point in points)
if (!uniquePoints.Exists(p => p.IsAlmostEqualTo(point)))
uniquePoints.Add(point);
return uniquePoints;
scgq425
Hi @dwightduronidavy :
in revit 2024 dont have NurbSpline with two arguments .
you can read this website and try again .
NurbSpline Members
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
dwightduronidavy
Thank you @scgq425 , will do some research
