Create Space in given Phase
AnatolyCEL
Message 1 of 8
AnatolyCEL
How can I create new Space in any (another than "New Constraction") Phase? I tried Document.NewSpace Method (Level, Phase, UV), but Space is created in "New Constraction" phase.
Anatoly.
Replies (7)
Message 2 of 8
xiaodong_liang
Autodesk Support
Autodesk Support
Hi Anatoly,
Per investigation, the phase of created space by Document.NewSpace(Level, Phase, UV) was determined by phase of view to which the space belongs, the given phase may not take effect if it’s not same with view’s phase. In addition, an SDK sample named AddSpaceAndZone only uses phase of active view.
Hope this helps.
Message 3 of 8
AnatolyCEL
Hello Liang,
I need to create new space in any of phase (user's choise) with API. Or move space from phase to another phase. Is it possible with API?
Anatoly.
Message 4 of 8
JimJia
hi Anatoly,
Revit doesn't not provide such API yet, you may refer to this blog: http://thebuildingcoder.typepad.com/blog/2009/03/create-room-on-level-in-phase.html
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: [email protected]
Message 5 of 8
Mustafa.Salaheldin
Please try the following code and mark it as an answer if it satisfies your aim. Open the new view with the new phase and run this addin. This will create a new phase with the same phase as the same view (or you can specify the phase directly in the function).
Note: You have to specify the UV point in the code so that it is located inside a closed boundary (4 walls for example)
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI.Events;
//using Autodesk.Revit.Collections;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
#endregion
namespace RevitAddinCS1
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class PlaceSpaceWithPhase : IExternalCommand
        #region Cached Variables
        private static ExternalCommandData _cachedCmdData;
        public static UIApplication CachedUiApp
            get
                return _cachedCmdData.Application;
        public static RvtApplication CachedApp
            get
                return CachedUiApp.Application;
        public static RvtDocument CachedDoc
            get
                return CachedUiApp.ActiveUIDocument.Document;
        #endregion
        #region IExternalCommand Members
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            _cachedCmdData = cmdData;
            try
                //TODO: add your code below.
                //Reference pickedRef = null;
                //Selection sel = CachedUiApp.ActiveUIDocument.Selection;
                //RebarPickFilter selFilter = new RebarPickFilter();
                //pickedRef = sel.PickObject(ObjectType.Element, selFilter, "Seleccione una Armadura");
                ////Obtener referencia
                //Element el = CachedDoc.GetElement(pickedRef);
                //Rebar myRebar = el as Rebar;
                //List<Curve> lc = myRebar.GetCenterlineCurves(true, true, false).ToList();
                Phase phase = CachedDoc.GetElement(CachedDoc.ActiveView.get_Parameter(BuiltInParameter.VIEW_PHASE).AsElementId()) as Phase;
                Transaction t = new Transaction(CachedDoc, "phase");
                t.Start();
                CachedDoc.Create.NewSpace(CachedDoc.ActiveView.GenLevel, phase, new UV(0, 0));
                t.Commit();
                return Result.Succeeded;
            catch (Exception ex)
                msg = ex.ToString();
                return Result.Failed;
        #endregion
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Message 6 of 8
michael-coffey
I know its been nearly 4 years since you posted this, but this is a bug in the API.   Your code assumes the phase of the current view but this not always desired.  Document.NewSpace Method (Level, Phase, UV) should take in any valid phase in the project and create the Space on that phase.  It currently does not do this.  It will take the phase of the current view, otherwise if current view doesn't have a phase (like a legend) then it takes the last phase in the project.  It basically ignores the phase input.  Please fix.
Message 7 of 8
mathieu.josserand
Up ! 🙂
Message 8 of 8
This is a pretty serious bug -- it makes automation of placing spaces per phase useless.  Space creation can be quite a time-consuming venture.
