Create room using pick point
adcdao
adcdao
Hi everybody,
I found some information about creating rooms but not exactly what I want. I want to be able to pick a point and create a room exactly as the Room command work and get information about the new room created (ID or UniqueID). Is it possible to do that?
Thank you very much,
André
smarente1
Use this method:
https://www.revitapidocs.com/2017/28262c8c-d18a-338c-eb17-f406438949d8.htm
Example:
from Autodesk.Revit.DB import UV
from rpw import revit, db
doc = revit.doc
uidoc = revit.uidoc
#Pick Room Point
point = uidoc.Selection.PickPoint()
#Active View
active = doc.ActiveView
#Active View Level
level_name = active.LookupParameter("Associated Level").AsString()
collect_levels = db.Collector(of_class = "Level")
active_level = [level for level in collect_levels if level.Name == level_name][0]
with db.Transaction(doc=doc, name="Create Room"):
    #Create Room
    new_room = doc.Create.NewRoom(active_level, UV(point.X,point.Y))
    #New Rooms Id
    new_room_Id = new_room.Id
adcdao
Thank you I will try that,
Is it possible to highlight the room boundary when moving cursor?
André
smarente1
It doesnt look like the PickPoint Method has a snap type option to highlight the boundary segments.
https://www.revitapidocs.com/2015/af8ad302-7196-8e2f-f1eb-e5929cda30d9.htm
adcdao
Thank you very much for your  help. Based on your code here's a simplified and more complete version:
//Pick point
Autodesk.Revit.DB.XYZ pickPoint;
ObjectSnapTypes snapTypes = ObjectSnapTypes.None;
pickPoint = uidoc.Selection.PickPoint(snapTypes, "Select a point inside the room to create");
UV roomLocation = new UV(pickPoint.X, pickPoint.Y);
//Level
Autodesk.Revit.DB.View activeView;
activeView = doc.ActiveView;
Level activeLevel = activeView.GenLevel;
//Create the room
ElementId roomID=null;
using (Transaction t = new Transaction(doc, "Create Room"))
try
t.Start();
Room newRoom;
newRoom = doc.Create.NewRoom(activeLevel, roomLocation);
roomID = newRoom.Id;
t.Commit();
catch ( Exception ex)
MessageBox.Show(ex.Message);
I also have a more complete version with failure options with the help of 2 posts by Jeremy Tammik:
https://thebuildingcoder.typepad.com/blog/2010/04/failure-api.html
https://thebuildingcoder.typepad.com/blog/2012/04/failure-rollback.html
Thank you again for your help.
