Jeremy post the code here to create directshape in the 3D view name {3D}. In some project when we have delete this view we can't re create them. Its possible to define a 3D view name as i would example Room volume?
thanks you for your answer
Best regards
Solved by jeremytammik. Go to Solution.
Yes, of course.
Or, rather, no, not at all.
A DirectShape element is a normal BIM element. It exists in the model itself. It forms part of the building that you are modelling. It is therefore view independent.
There is no need to specify a view when you create a Revit BIM element.
Dear Julien, thank you for your appreciation. My pleasure entirely 🙂
