Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Jeremy post the code here to create directshape in the 3D view name {3D}. In some project when we have delete this view we can't re create them. Its possible to define a 3D view name as i would example Room volume?
thanks you for your answer
Best regards
Solved by jeremytammik. Go to Solution.
Yes, of course.
Or, rather, no, not at all.
A DirectShape element is a normal BIM element. It exists in the model itself. It forms part of the building that you are modelling. It is therefore view independent.
There is no need to specify a view when you create a Revit BIM element.
Dear Julien, thank you for your appreciation. My pleasure entirely 🙂
