Create Ribbon and button with macro
GeorgK
Advisor Advisor
GeorgK
Hello together,
I am very new to Revit. Is it possible to create a ribbon and a button with a macro?
Thank you very much
Georg
stever66
I believe the Revit API says its not supported for the macros, however, I think it is possible.  Macros have  Module_Startup and Module_Shutdown segments that run when revit opens and closes.
The last time I tried adding a ribbon button with a macro, it ran correctly the first time, but caused an error message after it ran again.  But maybe I wasn't unloading it correctly on the shutdown.
You may need to use Joshua Lumley's "5 secrets of Revit API Coding" to get it to work, and it's not real basic:
https://thebuildingcoder.typepad.com/blog/2018/09/five-secrets-of-revit-api-coding.html#3
