Create Pipe from Points in list
zrodgersTSSSU
zrodgersTSSSU
Hey Everyone, Im trying to create pipes from a list of points. however i want to create the pipes between only between the closest points. Right now it will connect the points from the element in the order that it gets created.
EX:
i know im not iterating through the points correctly to do so. but i cant figure out search the list for the closest points and then draw the pipe between those...
Thanks ahead of time for any responses/guidance.
Here is my code so far:
if (form.ShowDialog() == DialogResult.OK)
                    //gets the level from form
                    ElementId slvlId = null;
                    if (form.sLevel.SelectedIndex > -1)
                        slvlId = (form.sLevel.SelectedItem as Level).Id;
                    //gets the system type from form
                    ElementId sysTypeId = null;
                    if (form.pSysType.SelectedIndex > -1)
                        sysTypeId = (form.pSysType.SelectedItem as PipingSystemType).Id;
                    //gets the pipe type from form
                    ElementId pTypeId = null;
                    if (form.pType.SelectedIndex > -1)
                        pTypeId = (form.pType.SelectedItem as PipeType).Id;
                    using (Transaction tx = new Transaction(doc))
                        tx.Start("Create Pipes");
                        List<XYZ> points = new List<XYZ>();
                        foreach (ElementId elemId in selectedIds)
                            Element elem = uidoc.Document.GetElement(elemId);
                            //bounding box around solid
                            BoundingBoxXYZ elemBB = elem.get_BoundingBox(doc.ActiveView);
                            //gets center of bounding box
                            XYZ bbCentroid = (elemBB.Max + elemBB.Min) / 2;
                            //add centroid points to list
                            points.Add(bbCentroid);
                        XYZ startPt = null;
                        XYZ endPt = null;
                        foreach (XYZ pt in points)
                            startPt = pt;
                            if (startPt != null && endPt != null)
                                Pipe pipe = Pipe.Create(doc, sysTypeId, pTypeId, slvlId, startPt, endPt);
                                endPt = pt;
                            else
                                endPt = pt;
                        tx.Commit();
mhannonQ65N2
It looks like you might want to create a Minimum Spanning Tree. You could try implementing this algorithm on the points and creating pipe for each edge in the resulting tree.
zrodgersTSSSU
I have read it and it seems that would be the same as using the distance to method. I just dont know how to structure the loops to iterate the points and compare them to eachother....
zrodgersTSSSU
Here is the solution that worked for me for anyone who needs it in the future!!
                            XYZ closestPoint = null;
                            foreach (XYZ point2 in points) //loop to find closest point
                                if(pt != point2)
                                    if (closestPoint == null)
                                        closestPoint = point2;
                                    if (pt.DistanceTo(point2) < pt.DistanceTo(closestPoint))
//create pipe here
