create parametric objects using the APIs
Can you also create parametric objects using the APIs?
We would like to generate a table to simple objects
eg. cuboid
By example, Type, length, width, height
Then gladly also attach additional metadata for each type.
jeremytammik
Dear Dede2286,
Before you try to work with the Revit API, it helps to have a basic understanding of the standard product usage from an end user point of view.
As soon as you explore the basics of using Revit, you will encounter the concept of families.
These represent exactly what you are asking for.
They can absolutely be generated programmatically as well:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.25
In the family environment, basic end user understanding is even more essential than in the project enviornment!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Thanks Jeremy
Only 1 question
Are there any restrictions on the use of the APIs for generating parametric objects.
eg.
can I use CSG (Void).
is the number of primitives or the parameter limited
Are there any examples to the API
Revitalizer
Hi DEDE2286,
to answer your "only 1" question:
Yes, but not every one is well documented.
E.g. when creating an Extrusion, there is a minimum ratio of thickness to the size of the input curves.
You cannot create one if it would be too flat.
Other restrictions must be evaluated by brute force:
http://thebuildingcoder.typepad.com/blog/2014/05/directshape-performance-and-minimum-size.html
And so on...
eg.
Yes, you can. There is a BooleanOperationUtils class for use in both project and family context.
Don't know, but I think you can add an unlimited number of parameters, especially those which just store geometry independent information, pieces of text, YesNo parameters,...
Have in mind that all of them will be displayed in the properties palette (forcing the user to scroll, scroll,...).
Also, if there are too many parameters to drive the geometry, it may result in constraints errors, dependig on the values you set.
If doing manually, the creator usually "flexes" a Family, testing several value ranges, observing the Family's behaviour.
The more complex, the more possible constraints errors.
Note that API just mimics what the user does.
In the SDK, there is a folder named "FamilyCreation".
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
