Create multiline text parametertype (sharedpatemater) via the api?
Message 1 of 8
It appears to that that there is no multiline text parametertype in Autodesk.Revit.DB.ParameterType (revit 2016). Is this true?
Replies (7)
Message 2 of 8
There isn't a multiline function in the GUI either. So I guess you can place a 'normal' text and use /r/n to go to the next line. (haven't tried this btw).
You can also make the textbox size smaller, so Revit will automatically place text to the next line.
Message 3 of 8
jeremytammik
Dear Nyo and Remy,
Thank you for your query and answer.
Yup, just like Remy says:
In general, if a feature is not available in the Revit product manually through the user interface, then the Revit API will not provide it either.
Therefore, before thinking about possibly automating any task, it is always important to explore the possibilities and develop an optimal solution through the user interface first.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 4 of 8
Like Remy says, you can use a normal string and add a new line where needed.
This is possible to do manually too, by either pasting multiline text from some texteditor or using CTRL + ENTER to go to the next line.
Goodluck,
/martin
Message 5 of 8
Why can't it be done via the UI? Maybe we are not talking about the same thing..
Manage->Shared Parameters->Create a new parameter
Message 6 of 8
jeremytammik
Dear Nvo,
You are right.
I believe this omission in the API was an oversight and will be corrected in the next major release.
Sorry about that.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 7 of 8
Thank you. I'm looking forward to it
Message 8 of 8
Dale.Bartlett
Not sure that this fits the question, but as mentioned above, you can use New Line to add multiple lines to a text parameter:
string s = string.Empty;
    List<string> ll = LinkTools.GetListLinks();
    foreach (string l in ll)
        // format list into string with returns
        s = s + "  \r\n" + Path.GetFileName(l);
    // update family parameters
    lstrParameterName = "LinkedFileList";
    lstrParameterValue = s;
    lblnSuccessLinks = ParameterTools.PutProjectInfoParameters(doc, lstrParameterName, lstrParameterValue);
Dale
______________
Yes, I'm Satoshi.
