Create Material with Appearance
selvakkani
selvakkani
I need to create the material with Appearance settings. And also i need to set the custom image for the appearance.
Is it possible to do using Revit API?
If possible, please provide sample code.
Omar_Amen
Hi @selvakkani ,
may you give the building coder solution a try : set-material-texture-path-in-editscope
Hope it fits your requirement ^^,
*the stack overflow post reference: Revit Api - Material with Texture from filepath
