Create Matchline
Create Matchline
Create Matchline
Is it possible to create a new Matchline in a dependent or any plan view?
I can get the OST_Matchline category with a collector and I can see post command can access the matchline command, however I want to create multiple, one in each view.
I also notice that the top and bottom constraints can be modified and the offsets cant in revit lookup. Its category is Annotation so maybe it can be created as a family instance?
jeremytammik
I don't know what a matchline is.
I suggest you create one manually in the user interface and then use RevitLookup and other API-based Revit database exploration tools to research what the exact result is, what elements that generates, what properties and relationships they have, etc.
Check out How to research to find a Revit API solution
https://thebuildingcoder.typepad.com/blog/2017/01/virtues-of-reproduction-research-mep-settings-onto...
Good luck, much success, and have fun!
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
