Create GlobalParameter
mahadev.v
mahadev.v
can anyone tell
how to create a Global Parameter
here 3rd argument is Parameter Type what that mean?
public static GlobalParameter Create(
	Document document,
	string name,
	ParameterType datatype
Mohamed_Arshad
HI @mahadev.v
   3rd Argument is ParameterType  i.e which type of value  you're going to save. (ex. Text,Number, Length, Area) use the
ParameterType  Enum for this.
Reference Code:
 Document doc = commandData.Application.ActiveUIDocument.Document;
            using (Transaction createGlobalParameter = new Transaction(doc, "Create Global Parameter"))
                createGlobalParameter.Start();
                //By using Parameter, use can able to fill only number
                GlobalParameter param = GlobalParameter.Create(doc, "Demo Length Parameter", ParameterType.Length);
                //By using Parameter, use can able to fill only Text
                GlobalParameter param_02 = GlobalParameter.Create(doc, "Demo Text Parameter", ParameterType.Text);
                createGlobalParameter.Commit();
Reference Output Image:
Hope this will helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
mahadev.v
Thanks a lot Mohammed 🙏.
let me try this 😊
mahadev.v
Hi Mohamed unfortunately Parameter type Enum is not Available in 2024 Version. can you tell me if you know the Solution.
Thank you
mahadev.v
my requirement is I want to disable or Un editable the Parameters.
if you know the solution then tell me it will be helpful for me.
Mohamed_Arshad
Hi @mahadev.v
 For Revit 2024, Instead of Enum Kindly use SpecTypeId.Length class for forgetypeId, Autodesk  have updated the Enum to class
Mohamed Arshad K
