Create floor elevation points
I'm creating  a plugin which compares floor with a point cloud. After the comparaison, I would like to create some point on this floor to change the elevation point by point in order to have Something similar to the point cloud. My problem is that i Don't find how to create thoses points using the revit API
If someone has the solution i'll take it ! thanks
jeremytammik
Do you mean like this?
Modify the Shape of a Roof or Structural Floor
https://help.autodesk.com/view/RVT/2021/ENU/?guid=GUID-D7240EA9-28EB-4F51-A474-371FA0DFBFAF
I would suggest exploring the options provided in the user interface first, before trying to address this programmatically.
Jeremy Tammik
Developer Technical Services
The Building Coder
Yes i would do this but in my plugin, Because i would automate the floor improvement.
I already know how it works with the user interface and i would add it to my plugin
RPTHOMAS108
Floor.SlabShapeEditor
Then
SlabShapeEditor.DrawPoint
If the Floor is not flat e.g. contains a slope direction arrow then this property will not be available to use.
OK Thanks a lot, i'll try it !
