Create FileSaveDialog Box
Iev60047
Iev60047
Seemingly simple question, but I had no luck searching around for the answer. I am trying to set the file path for an image I am exporting using C# in VisualStudio to create an .addin to use in Revit.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.DB.Architecture;
//We will not be committing any changes to the model, so read only for the transaction mode.
[Transaction(TransactionMode.ReadOnly)]
public class Main : IExternalCommand
    public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
        //Get application and document objects
        UIApplication uiapp = commandData.Application;
        Document doc = uiapp.ActiveUIDocument.Document;
        ImageExportOptions imgExportOpts = new ImageExportOptions();
            imgExportOpts.ZoomType = ZoomFitType.FitToPage;
            imgExportOpts.PixelSize = 500;
            imgExportOpts.FilePath = "C:/Users/username/Documents/Test.TIFF";
            imgExportOpts.FitDirection = FitDirectionType.Vertical;
            imgExportOpts.HLRandWFViewsFileType = ImageFileType.TIFF;
            imgExportOpts.ShadowViewsFileType = ImageFileType.TIFF;
            imgExportOpts.ImageResolution = ImageResolution.DPI_72;
            imgExportOpts.ShouldCreateWebSite = false;
        doc.ExportImage(imgExportOpts);
        //Returns success if programs runs well
        return Result.Succeeded;
I am thinking of adding:
        //Setting export path
        string filePath;
        public Return FileSaveDialog()
            filePath = ...
            return filePath
 somewhere after I define doc as a type of class Document. As you can tell I am not really sure what I am doing here. I tried looking at other examples and the revitapi help document, to no avail. I would be really grateful for any assistance. I am not sure if I should be doing something more like:
FileSaveDialog fileSaveDialog = new FileSaveDialog(string);
Stuff inside here;
jeremy_tammik
Iev60047
@jeremy_tammik I am trying my best here. Went through the internet search you provided, but it seems more aimed at actually saving a file. I am just trying to specify a file path. I do not need file output with the dialog.
        public string textBox1 = null;
    private void SaveButton_Click(object sender, EventArgs e)
            FileSaveDialog saveFileDialog1 = new FileSaveDialog();
            saveFileDialog1.InitialDirectory = @ "C:\";
            saveFileDialog1.Title = "Select path for image export";
            saveFileDialog1.CheckFileExists = true;
            saveFileDialog1.CheckPathExists = true;
            saveFileDialog1.DefaultExt = "TIFF";
            saveFileDialog1.Filter = "TIFF files (*.TIFF)|*.TIFF|All files (*.*)|*.*";
            saveFileDialog1.FilterIndex = 2;
            saveFileDialog1.RestoreDirectory = true;
            if (saveFileDialog1.ShowDialog() == DialogResult.OK)
                textBox1.Text = saveFileDialog1.FilePath;
I tried modifying a snippet I found, but to no avail.
nice3point
Just specify this path as a variable and you can use it anywhere
var imagePath = @"C:\Users\username\Desktop\Test.tif";
var options = new ImageExportOptions
    ExportRange = ExportRange.CurrentView,
    ZoomType = ZoomFitType.FitToPage,
    PixelSize = 500,
    FilePath = imagePath,
    FitDirection = FitDirectionType.Vertical,
    HLRandWFViewsFileType = ImageFileType.TIFF,
    ShadowViewsFileType = ImageFileType.TIFF,
    ImageResolution = ImageResolution.DPI_72,
    ShouldCreateWebSite = false,
doc.ExportImage(options);
jeremy_tammik
Sorry, I do not understand what your problem is. I thought that you wanted to specify the full file path when initialising the form and before displaying it to the user. Apparently, you have some other need. What is it? Please describe it as a black box. What input do you have? What is the desired output? What is the desired side effect?
Iev60047
Again thank you for  your help! Input is selection of folder through what I suppose is the FileSaveDialog. This selection of the folder will complete the call and return a value (the name of the folder, i.e. the desired file path) to a variable I have previously defined. I will then use this variable in the export method.
mhannonQ65N2
I'd recommend using the .NET SaveFileDialog instead of Revit's FileSaveDialog. The minimum you need to do is call the dialog's ShowFile method then put the value of its FileName property into your filePath variable.
This example, although it uses the OpenFileDialog, shows how to get the selected file name.
