Create FabricationPart using API
TigerEUEBW
TigerEUEBW
Hi, I am trying to create a FabricationPart using the API. I was able to retrieve the desired type for my FabricationPart (just the default Straight duct I downloaded from Autodesk cloud) but I'm not sure how to create it in Revit. I have looked into the create method for FabricationPart but the input is a FabricationServiceButton. I'm not sure how to grab the FabricationServiceButton - I have tried looking into RevitLookUp database but there is nothing for FabricationServiceButton.
I'm assuming this is the button that shows up when I open the MEP Fabrication Parts menu but I don't know how to retrieve it. Is there an easier way to create a FabricationPart? Or should I just use the .rfa family?
Moustafa_K
your first point to start looking for an answer is Revit sample SDK. there are almost an example of every know how.
see this example if it helps
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
