create Dynamo node based on API compiled
Ning_Zhou
Ning_Zhou
not strictly an API question but is it possible? i'm not an Dynamo expert so don't know if it's already doable? i mean using *.dll to create Dynamo node, basically port API to Dynamo
http://www.revitforum.org/dynamo-bim/27488-space-room-spase.html
Aaron.Lu
Hi Ning,
You can check this out:
https://github.com/DynamoDS/DynamoSamples
Aaron Lu
Developer Technical Services
Autodesk Developer Network
Ning_Zhou
thanks Aaron for the link, so it's positive? i'll try it later
Aaron.Lu
yes.
Aaron Lu
