Create DirecShape
Create DirecShape
NhuTruong_BeyCons
Message 1 of 8
Create DirecShape
NhuTruong_BeyCons
I tried to create DirecShape according to the sample code. I changed DirectShape.CreateElement () method to DirectShape.CreateElementInstance () method but it was null value. Hope everyone helps me. Thanks.
public void CreateSphereDirectShape(Document doc)
List<Curve> profile = new List<Curve>();
XYZ center = XYZ.Zero;
double radius = ConvertUnits.MilimeterToFeet(500);
XYZ profile00 = center;
XYZ profilePlus = center + new XYZ(0, radius, 0);
XYZ profileMinus = center - new XYZ(0, radius, 0);
profile.Add(Line.CreateBound(profilePlus, profileMinus));
profile.Add(Arc.Create(profileMinus, profilePlus, center + new XYZ(radius, 0, 0)));
CurveLoop curveLoop = CurveLoop.Create(profile);
SolidOptions options = new SolidOptions(ElementId.InvalidElementId, ElementId.InvalidElementId);
Frame frame = new Frame(center, XYZ.BasisX, -XYZ.BasisZ, XYZ.BasisY);
if (Frame.CanDefineRevitGeometry(frame) == true)
Solid sphere = GeometryCreationUtilities.CreateRevolvedGeometry(frame, new CurveLoop[] { curveLoop }, 0, 2 * Math.PI, options);
using (Transaction t = new Transaction(doc, "Create sphere direct shape"))
t.Start();
DirectShapeType directShapeType = DirectShapeType.Create(doc, "Tested", new ElementId(BuiltInCategory.OST_GenericModel));
DirectShape ds = DirectShape.CreateElementInstance(doc, directShapeType.Id, directShapeType.Category.Id, Guid.NewGuid().ToString(), Transform.Identity);
ds.ApplicationId = "Application id";
ds.ApplicationDataId = "Geometry object id";
ds.SetShape(new GeometryObject[] { sphere });
t.Commit();
Replies (7)
Message 2 of 8
jeremytammik
Please read the CreateElementInstance documentation:
https://www.revitapidocs.com/2020/2a44c4e3-5056-eb56-f849-a7e9dcc478da.htm
The fourth argument is:
definitionId
Type: System String
Id of the shape definition that was created earlier and stored via DirectShapeLibrary.
You are passing in Guid.NewGuid().ToString() for the definition id.
That does not look as if it fulfils the stated requirements.
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 8
jeremytammik
The Building Coder has shared numerous samples showing how to create direct shapes:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.50
The easiest solution for you would be to use one of those.
Unfortunately, I do not think any of them demonstrate using a direct shape library.
Therefore, it would be interesting to implement such an example.
If you have good reasons to implement and use such a library, I will happily help with that.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
Message 4 of 8
jeremytammik
Please always spell check your query carefully, especially the title.
'DirecShape' will not be found by people searching for 'DirectShape'.
Jeremy Tammik
The Building Coder
Message 5 of 8
NhuTruong_BeyCons
I have the python code but don't know how to switch to C #. Can you help me?
# Copyright(c) 2017, Dimitar Venkov
# @5devene, dimitar.ven@gmail.com
# www.badmonkeys.net
import clr
import System
import sys
from System.Collections.Generic import *
from itertools import repeat
pf_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.ProgramFilesX86)
sys.path.append("%s\IronPython 2.7\Lib" % pf_path)
import traceback
clr.AddReference('ProtoGeometry')
from Autodesk.DesignScript.Geometry import *
clr.AddReference("RevitServices")
import RevitServices
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
doc = DocumentManager.Instance.CurrentDBDocument
app = DocumentManager.Instance.CurrentUIApplication.Application
isRvt2017 = int(app.VersionNumber) > 2016
clr.AddReference("RevitNodes")
import Revit
clr.ImportExtensions(Revit.Elements)
clr.ImportExtensions(Revit.GeometryConversion)
clr.AddReference("RevitAPI")
import Autodesk.Revit.DB as RVT
def tolist(obj1):
    if hasattr(obj1, "__iter__"):
        return obj1
    else:
        return [obj1]
def PadLists(lists):
    len1 = len(lists[0])
    for i in xrange(1, len(lists)):
        len2 = len(lists[i])
        if len2 == len1:
            continue
        elif len2 > len1:
            lists[i] = lists[i][:len1]
        else:
            lists[i].extend(repeat(lists[i][-1], len1 - len2))
    return lists
def NewDS(s1, cat1, name1):
    temp_path = System.IO.Path.GetTempPath()
    sat_path = "%s%s.sat" % (temp_path, name1)
    try:
        if factor != 1:
            s1 = s1.Scale(factor)
        sat1 = Geometry.ExportToSAT(s1, sat_path)
        satId = doc.Import(sat1, satOpt, view1)
        el1 = doc.GetElement(satId)
        geom1 = el1.get_Geometry(opt1)
        enum = geom1.GetEnumerator()
        enum.MoveNext()
        geom2 = enum.Current.GetInstanceGeometry()
        enum2 = geom2.GetEnumerator()
        enum2.MoveNext()
        s1 = enum2.Current
        doc.Delete(satId)
        System.IO.File.Delete(sat_path)
        if cat1 is None or not RVT.DirectShape.IsValidCategoryId(cat1.Id, doc):
            cat1Id = RVT.ElementId(RVT.BuiltInCategory.OST_GenericModel)
        else:
            cat1Id = cat1.Id
        if name1 in dst_enum:
            old_type = dst_enum[name1]
            old_type.SetShape([s1])
            fec1 = RVT.FilteredElementCollector(doc).OfClass(RVT.DirectShape).WhereElementIsNotElementType()
            insts = [i for i in fec1 if i.GetTypeId().Equals(old_type.Id)]
            if insts:
                ds1 = insts[0]
            else:
                dsLib.AddDefinitionType(name1, old_type.Id)
                if isRvt2017:
                    ds1 = RVT.DirectShape.CreateElementInstance(doc, old_type.Id, cat1Id, name1, tf1)
                else:
                    ds1 = RVT.DirectShape.CreateElementInstance(doc, old_type.Id, cat1Id, name1, tf1, "Dynamo",
        "spring nodes")
                ds1.SetTypeId(old_type.Id)
        else:
            dsType1 = RVT.DirectShapeType.Create(doc, name1, cat1Id)
            dsType1.SetShape([s1])
            dsLib.AddDefinitionType(name1, dsType1.Id)
            dst_enum[name1] = dsType1
            if isRvt2017:
                ds1 = RVT.DirectShape.CreateElementInstance(doc, dsType1.Id, cat1Id, name1, tf1)
            else:
                ds1 = RVT.DirectShape.CreateElementInstance(doc, dsType1.Id, cat1Id, name1, tf1, "Dynamo",
                                                            "spring nodes")
            ds1.SetTypeId(dsType1.Id)
        return ueWrapper.Invoke(None, (ds1, False))
    except:
        return traceback.format_exc()
solids = tolist(IN[0])
cat = map(UnwrapElement, tolist(IN[1]))
names = tolist(IN[2])
satOpt = RVT.SATImportOptions()
satOpt.Placement = RVT.ImportPlacement.Origin
satOpt.Unit = RVT.ImportUnit.Foot
opt1 = RVT.Options()
opt1.ComputeReferences = True
acceptable_views = "ThreeD, FloorPlan, EngineeringPlan, CeilingPlan, Elevation, Section"
view_fec = RVT.FilteredElementCollector(doc).OfClass(RVT.View)
view1 = None
for v in view_fec:
    if v.ViewType.ToString() in acceptable_views and not v.IsTemplate:
        view1 = v
        break
units = doc.GetUnits().GetFormatOptions(RVT.UnitType.UT_Length).DisplayUnits
factor = RVT.UnitUtils.ConvertToInternalUnits(1, units)
dsLib = RVT.DirectShapeLibrary.GetDirectShapeLibrary(doc)
tf1 = RVT.Transform.Identity
dst_fec = RVT.FilteredElementCollector(doc).OfClass(RVT.DirectShapeType)
dst_enum = dict((RVT.Element.Name.__get__(i), i) for i in dst_fec)
ueWrapper = None
wrappers = clr.GetClrType(Revit.Elements.ElementWrapper).GetMethods()
for w in wrappers:
    if w.ToString().startswith("Revit.Elements.UnknownElement"):
        ueWrapper = w
        break
if len(solids) == len(names):
    if not len(solids) == len(cat):
        padded = PadLists((solids, cat))
        cat = padded[1]
    TransactionManager.Instance.EnsureInTransaction(doc)
    OUT = map(NewDS, solids, cat, names)
    TransactionManager.Instance.TransactionTaskDone()
else:
    OUT = "Make sure that each geometry\nobject has a unique type name."
satOpt.Dispose()
opt1.Dispose()
Message 6 of 8
NhuTruong_BeyCons
Thank you for your prompt. How to edit the title?
Message 7 of 8
NhuTruong_BeyCons
Thank you. I have solved this problem as follows
                    t.Start();
                    DirectShapeLibrary directShapeLibrary = DirectShapeLibrary.GetDirectShapeLibrary(doc);
                    directShapeType.SetShape(new List<GeometryObject>() { sphere });
                    directShapeLibrary.AddDefinitionType("Tested", directShapeType.Id);
                    DirectShape ds = DirectShape.CreateElementInstance(doc, directShapeType.Id, directShapeType.Category.Id, "Tested", Transform.Identity);
                    ds.SetTypeId(directShapeType.Id);
                    t.Commit();
Message 8 of 8
jeremytammik
Congratulations on solving this.
I repeat my question: are you sure you know what you are doing, creating a direct shape type and an instance for that?
It probably makes a lot of sense if you have many instances.
If you only need one single instance, I would imagine that it would be easier and more efficient not to create a type and an instance, but just create a normal direct shape element directly.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
