Create Dimension Revit API
peerawit.ru
peerawit.ru
Hi everyone
I try to create add-in for new dimension
and i use pickpoint to create line for dimension.
It work on view plan but in elevation or section it not allowed to pick except setting active workplan in view before execute.
Can i fix it?
Thank for your recommend.
architect.bim
Hi!
Here is the method that for each view, sets the working plane that passes through its Origin. You can call it before you access the PickPoint method.
public void SetViewDefaultWorkPlane(View view)
    SketchPlane sketchPlane = SketchPlane.Create(
        doc,
        Plane.CreateByNormalAndOrigin(
            view.ViewDirection,
            view.Origin
    view.SketchPlane = sketchPlane;
using (Transaction t = new Transaction(doc, "Set View Default Work Plane"))
    t.Start();
    SetViewDefaultWorkPlane(view);
    t.Commit();
Maxim Stepannikov | Architect, BIM Manager, Instructor
peerawit.ru
Thankyou very much 😁
