create dimension between reference plane and element
Yonas89
Yonas89
Hello  I am trying to create a linear dimension between top reference plane and element. In order to do that I need to add desired element's edge to referenceArray. However I don't know how to access this edge through api. Which property or method should I use to add this edge(red arrow in picture) to referenceArray.
JimJia
Dear Jonas Grazys,
The NewDimension API accepts ReferenceArray as method parameter which consits of references, so you just need to build references array.
For ReferencePlane, we can get reference form ReferencePlane directly via ReferencePlane.GetReference().
If you want to access reference of element edge, you can get it from element geometry, some code snippet:
Options opt = new Options();
opt.ComputeReferences = true; // ensure to use true to return reference
foreach(var gobj in element.get_geometry(opt ))
    if(gob is Edge)
          Reference edgeRef = (gobj as Edge).Reference; // access reference from edge
You may need to refere to pages below on more related:
http://thebuildingcoder.typepad.com/blog/2015/05/how-to-retrieve-dimensioning-references.html
http://thebuildingcoder.typepad.com/blog/2009/10/revit-family-creation-api-labs.html
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
Yonas89
@JimJia,
thank you for your reply. I may haven't used the right terms in my question, cause I'm still relatively new to Revit. It's a swept profile and not a solid element, thus the term Edge, is not really good here. However I was able to solve this. I needed to use  get family instance of this element and use  "GetReferenceByName" method . In this particular example the name is "Right". It worked for me just fine.
LTusche1
Hello @JimJia,
when I append ReferencePlane.GetReference() to the ReferenceArray I just get the exception:
"The references are not geometric references."
Do you have an idea what could cause for this?
Maybe it has to do with the ReferenceType?
The Reference in the Dimension is REFERENCE_TYPE_SURFACE while the reference that you get from ReferencePlane.GetReference() is REFERENCE_TYPE_NONE.
lo_t_tran
You need to call document.Regenerate(); after creating the ReferencePlane.
