Create customised note block
navyabasavaraju01
navyabasavaraju01
Is there any way create customised noteblock in revit api and I need to add instance parameter to schedule after its creation.
Regards
Navya Y.B
jeremytammik
Yes, certainly.
However, I would suggest that you research how to achieve what you need and the optimal workflow and best practices to achieve it manually through the user interface first.
Once you have that part understood, cleaned up and optimised for your needs, it will be time to look at the programming aspects.
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
