Create Custom Surface Patterns Using Revit API
When creating surface patterns in Mass, we are only limited in the patterns provided by its properties (as shown)
Is there a way we can use the API to drive custom surface patterns like patterns created in Autocad for example?
Btw, there is a ParameterValuesFromImage sample from the SDK but that iis using an image to drive parameters (not exactly what you want if you have precised and approved dwg patterns from a client that you want to use as surface patterns in your Revit model).
Any ideas if its possible using the API is greatly appreciated. thank you.
nj19790605
I also want to know
Revitalizer
in the RevitAPI.chm, it says:
"TilePatterns cannot be created. A fixed selection is built into each Conceptual Mass family. TilePatterns can be retrieved by key from the Revit.DB.Document.Settings.TilePatternTable object."
->They cannot be created.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
