Create Curtain System
I am new to Revit. I want to create a Curtain System for the selected faces. To create, I can call the method
CurtainSystem cs = document.Create.NewCurtainSystem() which takes two parameters. I can get the facearray from the user selection. But I am not knowing how to create a CurtainSystemType which is the second parameter. Is there any sample code for this?
Also, can i colour the curtain system with multiple colors (different color for each grid) ?
aignatovich
Hi!
You can use FilteredElementCollector to retrieve all CurtainSystemTypes or you can use doc.GetDefaultElementTypeId(ElementTypeGroup.CurtainSystemType)
1)
var collector = new FilteredElementCollector(doc);
var cst = collector.OfClass(typeof(CurtainSystemType)).OfType<CurtainSystemType>().FirstOrDefault(x => <your condition>);
2)
var cstId = doc.GetDefaultElementTypeId(ElementTypeGroup.CurtainSystemType);
var cst = (CurtainSystemType)doc.GetElement(cstId);
aignatovich
About your second question. You can get curtain system curtain grids, then for each curtain grid get panels, and override graphics for specific views
