Create Color Scheme
Create Color Scheme
Create Color Scheme
I am referring to another forum topic <https://forums.autodesk.com/t5/revit-ideas/api-for-color-schemes-and-ability-to-control-rgb-colors/i...>
Does Revit API has any function to create color scheme? (for Areas specifically )
I also hope API has function to add/remove color scheme.
Alternatively, is there any API to define filters for areas in-order for me to change the color of areas.
Many thanks in advance for your kind attention
aignatovich
Hi!
There is still no API for color schemes in current Revit version.
But you can create view filters and set yours colors and fill patterns. First of all you need to create ParameterFilterElement (or find existing one in the model). Look at ParameterFilterElement.Create static method. Then create filters (look at methods from ParameterFilterRuleFactory) and add them to your filter.
Then add filter to your view, just call view.AddFilter(filter.Id) and override graphic representation. Look at view.GetFilterOverrides / view.SetFilterOverrides and to the methods from OverrideGraphicSettings class.
jeremy_tammik
Please check the public Revit roadmap:
https://blogs.autodesk.com/revit/2020/11/10/revit-public-roadmap-update-november-2020/
I just did, and have good news for you; Color Scheme API was released in Revit 2022:
https://trello.com/c/iKJRNvNS/53-color-scheme-api
Yup, I see it in the list of what's new:
2.2. Color Fill API
https://thebuildingcoder.typepad.com/blog/2021/04/whats-new-in-the-revit-2022-api.html#4.2.2
Cheers,
Jeremy
