Create and modify Global Type Parameter with API
nicolas.calvi
nicolas.calvi
I try to create on runtime (API and C# on Revit 2020) some Global Parameter to a Type and set a default value.
Currently I do it with Shared Parameter, but I want to do it with Global Parameter of the current document.
Is there a way to acheive this with API ?
Thanks.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi  @nicolas.calvi ,
Global parameters may be created only in Project documents, not in families.
Global parameters can be created with almost any type of data, there are a few types that are not currently supported, such as the ElementId type. Programmers can test whether a particular data type is appropriate for a global parameter by using the IsValidDataType(ParameterType) method.
1)Create a global parameter
https://www.revitapidocs.com/2016/57899395-e9df-4066-121d-046ee7a7425e.htm
2)Set value to global parameter
https://www.revitapidocs.com/2020/df012c22-6e65-8de5-1057-f15660d02288.htm
Also, have a look at this below link
https://forums.autodesk.com/t5/revit-api-forum/get-or-set-global-parameter-group/td-p/9172280
https://www.revitapidocs.com/2020/f3af05ec-1f0c-fe86-6708-0a211a40bcda.htm
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
nicolas.calvi
Thanks, we try have a look to your links.
nicolas.calvi
Ok, I think there was a problem of understanding. I'm actually trying to create a global (unshared) project setting, as the screenshot below shows.
How do you do this with the Revit API.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @nicolas.calvi ,
The dialog box in your screenshot image is related to the project parameter and shared parameters but not related to the global parameter.
The global parameter is different from the project parameter.
I think you are trying to create a project parameter.
I think it is not possible to create a non-shared project parameter via Revit API but you can create a shared project parameter via Revit API.
https://spiderinnet.typepad.com/blog/2011/05/parameter-of-revit-api-31-create-project-parameter.html
I hope this helps.
Naveen Kumar T
