Create and Connect to SQLite Database (DB) in C#
rvtquestions
rvtquestions
As the title suggests I need to create and connect to a SQL DB to start. I know there are many specific forums for it but I am here because I have gotten it to fully work in the Revit context via Python but having difficulty translating it to C# in context to the Revit API.
I can create a new db by:
                string filePath = @"C:\Users\User\Desktop\Test.db";
                SQLiteConnection.CreateFile(filePath);
But when I try to open the connection, it does not work.  (Code just terminates/fails).
string ds = "Data Source=" + filePath + ";Version=3;";
SQLiteConnection c = new SQLiteConnection(ds);
c.Open();
I've tried many configurations, such as:
  • placing the code in a try/catch block
  • formatting the ds string different ways
  • writing the connection line with a using statement
but they all fail. This should be the simplest step but it appears I am missing something. Can anyone who has gotten SQLite connections to work via C# shed any light to this? Thank you.
jeremy_tammik
Fundamentally there is no significant difference between .NET in Python and C#.
Can you share a minimal complete Python sample code snippet that successfully completes the db connection?
MarryTookMyCoffe
I use sqlite in my revit app and it work like charm, but I only put path to connection. What nuget do you use?
try doing it in application out side revit to see where problem is.
do not worry it only gonna take Autodesk 5 years to fix bug
rvtquestions
Hi Jeremy! Sure, in Python the aforementioned steps would be easily achieved by writing:
import sqlite3
conn = sqlite3.connect(r'C:\Users\User\Desktop\Test.db')
and then you can follow by executing lines of commands but that is beyond the scope of the initial question.
rvtquestions
I believe the packages are as follows:
System.Data.SQLite v.1.0.115
System.Data.SQLite.Core v.1.0.115.5
jeremy_tammik
I would suggest taking a look at the internal implementation of the `connect` method in the Python sqlite3 package. It is open source, isn't it? Then, you can simply reproduce the same steps in C#.
