Create aligned dimension between rebars
I was trying to create new aligned dimension between rebars. The error message I'm getting is: The references are not geometric references.
Is there a work around so that I can create dim for rebars?
I was able to solve the issue. Rebar doesn't give any geometry. So all trial to generate dim from Rebar was failing.
The method I tried was with the ActiveView, selected rebar Options.
Snippet
Options options = new Options();
options.ComputeReferences = true; options.IncludeNonVisibleObjects = true; //options.DetailLevel = ViewDetailLevel.Fine; options.View = uiDoc.Document.ActiveView;
If I select the Geometry Elements from this and filter only lines, I can get the reference of that lines.
Hope this helps someone in future.
