Create a support at one corner of an AnalyticalPanel
junlin001
junlin001
Is there a way to create a single support at one corner of an analytical panel? I tried the following and it does not work
CurveArray curves = new CurveArray();
Utils.GetCurves(analyticalPanel, ref curves);
var curve = curves.get_Item(curveIndex);
AnalyticalCurveSelector analyticalCurveSelector = (nodes[curveIndex] == support.Id) ? AnalyticalCurveSelector.WholeCurve : AnalyticalCurveSelector.WholeCurve;
AnalyticalModelSelector selector = new AnalyticalModelSelector(curve, analyticalCurveSelector);
Reference reference = analyticalPanel.GetReference(selector);
TranslationRotationValue[] fixity = new TranslationRotationValue[6];
for (int i = 0; i < 6; i++)
fixity[i] = (support.Flag[i] == '1') ? TranslationRotationValue.Fixed : TranslationRotationValue.Release;
condition = _document.Create.NewPointBoundaryConditions(reference,
fixity[0], 0,
fixity[1], 0,
fixity[2], 0,
fixity[3], 0,
fixity[4], 0,
fixity[5], 0);
Any help is greatly appreciated.  Thanks.
rnilay81
Can you give more details as to what actually is not working? Also , check couple of things
1) Have you loaded the boundary conditions in the model ? Either programmatically or in the Template file(if you are using one) ?
2) Please note, if the boundary conditions are not loaded , then even though you add the Support programmatically you won't be able to see them on the model. Simple way to check they are loaded is to open your model , go to "Manage"--> "Structural Settings" ---> "Bounday Conditions Settings" . If they are not there, you will get a popup as below
junlin001
Let's say I have the following four analytical panels.  Is there a way to create point boundary conditions at four corners in Revit either through UI or programmatically.   It seems that point boundary conditions can only applied to analytical members in Revit.  If that is the case, it would be a mistake as point boundary conditions should be allowed on any given nodes.
rnilay81
As I understand from the figure above, you want to apply point boundary conditions to corners of each of the analytical Panel. As far as I know, you can't apply the Point boundary condition to any one corner of the Analytical Panel. You can apply line or area Boundary Conditions in such cases.
junlin001
Yes, that is my conclusion too.  I think it is a mistake for Revit not allowing point boundary condition to be applied at the corners of analytical panels.  It seems that people who design the API have not much structural analysis or FEM modeling experiences.  There are also so many breaking changes over the years with every Revit upgrade.  And lastly, I feel Revit software is over-bloated and very slow.
