Create a Pipe cap
Create a Pipe cap
Hello everybody!!
I come from here:
http://thebuildingcoder.typepad.com/blog/2011/02/create-a-pipe-cap.html
I need to recue this old post because I have followed the code, but my pipe cap is not aligned correctly with the pipe, so I can't connect it to the pipe
Please find attached a zip file with a model with a macro just in case someone wanted to help me 😞
many tanks in advance!!
Chema
Replies (9)
Mustafa.Salaheldin
Dear Chema
Please find here the code that will do all the magic:
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI.Events;
//using Autodesk.Revit.Collections;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
using System.Diagnostics;
#endregion
namespace RevitAddinCS2
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class ExtCmd : IExternalCommand
        #region Cached Variables
        private static ExternalCommandData _cachedCmdData;
        public static UIApplication CachedUiApp
            get
                return _cachedCmdData.Application;
        public static RvtApplication CachedApp
            get
                return CachedUiApp.Application;
        public static RvtDocument CachedDoc
            get
                return CachedUiApp.ActiveUIDocument.Document;
        #endregion
        #region IExternalCommand Members
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            _cachedCmdData = cmdData;
            InsertPipeCap("Cap - PVC - Sch 40");
            return Result.Succeeded;
        public void InsertPipeCap(string FamilyName)
            FamilySymbol fS = null;
            FilteredElementCollector collector = new FilteredElementCollector(CachedDoc);
            collector.OfCategory(BuiltInCategory.OST_PipeFitting).OfClass(typeof(FamilySymbol));
            FamilySymbol placeholder = collector.Cast<FamilySymbol>().Where(p => p.FamilyName == FamilyName).FirstOrDefault();
            if (placeholder != null)
                fS = placeholder;
            Reference r = CachedUiApp.ActiveUIDocument.Selection.PickObject(ObjectType.Element, "select a pipe");
            Element el = CachedDoc.GetElement(r);
            Pipe pipe = el as Pipe;
            LocationCurve lC = pipe.Location as LocationCurve;
            Curve cu = lC.Curve;
            XYZ startPoint = cu.GetEndPoint(0);
            Options opt = new Options();
            opt.ComputeReferences = true;
            opt.DetailLevel = ViewDetailLevel.Fine;
            GeometryElement e = pipe.get_Geometry(opt);
            Face normalFace = null;
            double dist = double.MaxValue;
            foreach (GeometryObject obj in e)
                Solid solid = obj as Solid;
                if (solid != null && solid.Faces.Size > 0)
                    foreach (Face face in solid.Faces)
                        PlanarFace pf = face as PlanarFace;
                        if (pf != null)
                            if (pf.Origin.DistanceTo(startPoint) < dist)
                                normalFace = pf;
                                dist = pf.Origin.DistanceTo(startPoint);
            Connector CapConnector = null;
            using (Transaction t = new Transaction(CachedDoc))
                t.Start("insert fixture");
                using (SubTransaction sb = new SubTransaction(CachedDoc))
                    sb.Start();
                    fS.Activate();
                    FamilyInstance fi = CachedDoc.Create.NewFamilyInstance(startPoint, fS, normalFace.ComputeNormal(new UV(0.5, 0.5)), CachedDoc.ActiveView.GenLevel, StructuralType.NonStructural);
                    ConnectorManager cm = fi.MEPModel.ConnectorManager;
                    ConnectorSet fCS = cm.Connectors;
                    foreach (Connector c in fCS)
                        if (c != null)
                            CapConnector = c;
                            break;
                    sb.Commit();
                Connector PipeConnector = null;
                    sb.Start();
                    XYZ fCP = CapConnector.Origin;
                    ConnectorSet pCS = pipe.ConnectorManager.Connectors;
                    foreach (Connector c in pCS)
                        if (c.Origin.DistanceTo(fCP) < dist)
                            dist = c.Origin.DistanceTo(fCP);
                            PipeConnector = c;
                    CapConnector.Radius = PipeConnector.Radius;
                    sb.Commit();
                    sb.Start();
                    CapConnector.ConnectTo(PipeConnector);
                    ConnectorSet cs = CapConnector.AllRefs;
                    sb.Commit();
                t.Commit();
        #endregion
Use the attached Family and don't forget to assign the lookup file. I couldn't find the Cap family in your file so I used the one I attach.
Please if this code satisfies your need mark this reply as an answer.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Dear Mustafa,
thanks SO much for this brilliant solution!!! Now I can follow developing my tool!!!
In addition I would like to show you something.
When using it workflow in a vertical or sloped pipe, the cap is well connected but graphically it is not good placed. After the cap being inserted, it is shown ar per the next snapshot:
undefined
After that, if I move slightly the pipe (even using the arrow key) the cap is placer perfect:
undefined
Do you have any idea how to solve this (minor) inconvenience?
thanks!!!
Mustafa.Salaheldin
I thought I'll deserve a Kudod Smiley Very Happy don't worry I'll work on it and see how it is going with sloped pipes.
¯\_(ツ)_/¯
Mustafa Salaheldin
Mustafa.Salaheldin
Try this and tell me if it works as a charm:
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.IO;
#endregion
            get
            get
            get
        #endregion
                fS = placeholder;
                        if (pf != null)
                                normalFace = pf;
                    sb.Start();
                    fS.Activate();
                        if (c != null)
                            CapConnector = c;
                            break;
                    sb.Commit();
                    sb.Start();
                        if (c.Origin.DistanceTo(fCP) <= dist)
                            PipeConnector = c;
                    sb.Commit();
                    sb.Start();
                    sb.Commit();
                t.Commit();
        #endregion
If you still have problems just send me the RVT with the family that causing the problem.
If this reply satisfies your need mark it as a solution.
This is my Result:
undefined
¯\_(ツ)_/¯
Mustafa Salaheldin
What is the difference between both codes???
Mustafa.Salaheldin
The proximity condition has been changed:
                            PipeConnector = c;
instead of less than use less than or equal. Has it work?
¯\_(ツ)_/¯
Mustafa Salaheldin
Hi!
It makes the same issue... It seems to me that it is a "regeneration problem" because if i move the pipe after placin the cap it reactions and go to the correct place.....
Mustafa.Salaheldin
Ok just add doc.regenerate() and tell me the result.
¯\_(ツ)_/¯
Mustafa Salaheldin
Dear Mustafa,
I was trying to use your solution to place cap on open ended pipes;
Depending in type of caps In Some cases this works:
FamilyInstance fi = CachedDoc.Create.NewFamilyInstance(cn.Origin, fS, StructuralType.NonStructural);
and is some this works:
FamilyInstance fi = CachedDoc.Create.NewFamilyInstance(cn.Origin, fS, normalFace.ComputeNormal(new UV(0.5, 0.5)), CachedDoc.ActiveView.GenLevel, StructuralType.NonStructural);
How do I know which method of NewFamilyInstance to use.
Thanks & Regards
Sanjay Pandey
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
