Could I get another FamilyInstance when using NewElbowFitting
tristaVXAM4
tristaVXAM4
There are two pipes with different diameters.
When I use "NewElbowFitting" to create fitting, revit would create two fittings.
But the "familyInstance" means the elbow, not both of them.
familyInstance = doc.Create.NewElbowFitting(conn1, conn2);
How to get the familyInstance of the other fitting?
Thank you.
ankofl
I think there is no built-in function, but you can go through the connectors of your tap and find the connected fitting of the transition through this.
ctm_mka
try subscribing to a Document changed event, its should give you the elementids of both objects each time a newelbow is created.
private void OnElemCreation(object sender, DocumentChangedEventArgs e)
e.GetAddedElementIDs(); //should have all the element ids at time of creation
tristaVXAM4
It works!!! Thank you~
