Copy with base point
Message 1 of 19
How do I call copy with base point via api.
Thanks & Regards
Sanjay Pandey(BIM[Revit] Developer)
Replies (18)
Message 2 of 19
stever66
Something like this:
Selection selection = uidoc.Selection;
ICollection<ElementId> selectedIds = uidoc.Selection.GetElementIds();
XYZ point1 = new XYZ(0, 0, 0);
XYZ point2 = new XYZ(0, 0, 0);
XYZ point3 = new XYZ(0, 0, 0);
point1 = selection.PickPoint("Please pick a base point.");
point2 = selection.PickPoint("Please pick a point to place elements");
point3 = point2.Subtract(point1);
t.Start();
ICollection<ElementId> pastedIds = ElementTransformUtils.CopyElements(doc, selectedIds, point3);
t.Commit();
The view must have a workplane set for the PickPoint to work.  With a workplane set, this will work in plan views, elevation views, and even 3D views.
Message 3 of 19
Mustafa.Salaheldin
I can't understand the question, can you clarify more please?
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Message 4 of 19
I have a group whose group origin i have changed. Now How do I find the center point of the group. because after changing the group origin to the top left the rotation of the group is not working properly.
Thanks & Regards
Message 5 of 19
Revitalizer
for the group's center point, why not get the bounding boxes of the members and then calculate it ?
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 6 of 19
Thanks for the suggestion.
How about getting the bounding box of the group itself and getting the center.
Thanks & Regards
Sanjay Pandey
Message 7 of 19
Revitalizer
Hi sanjayman,
I've already seen that you created another thread for the Group center point.
http://forums.autodesk.com/t5/revit-api/group-center-point/td-p/6379898
As far as I can see, there are about three types of Groups:
  1. Model groups
  2. Detail groups
  3. Model groups with attached Detail groups
Each group consists of a list of members.
You can get the members' BoundingBoxes, this method needs a View parameter.
Depending on the kind of the group,use the View the Element resides in (Detail group) or null (for Model group).
May be that you need to use a valid View3D instead of null, in this case.
For the third case, I have no idea so far.
Once having the BoundinBoxXYZ for each Element in a group, get their minimum and maximum extends.
Calculate the center of the extends by dividing it by two...
(Remark: Groups can contain groups.)
That's all.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 8 of 19
I am only dealing with Model Groups[no detail group attached nor any group within group]. After replying to you I tried to do :
1. got the bounding box of the group group.get_BoundingBox(activeview)
2. divide the max and min by two.
but results are quiet badSmiley Frustrated
Thanks & Regards
Message 9 of 19
Revitalizer
not the BoundingBox of the Group itself but those boxes of its members.
Get the member Elements (respectively their Ids) by Group.GetMemberIds().
Note that Groups can be embedded recursively, a Group's member could be another Group, since a Group is an Element itself.
For a Model group, I wouldn't use the ActiveView since the result will be view depending.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 10 of 19
Mustafa.Salaheldin
Please try this and tell me the result:
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI.Events;
//using Autodesk.Revit.Collections;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
#endregion
namespace RevitAddinCS5
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class ExtCmd : IExternalCommand
        #region Cached Variables
        private static ExternalCommandData _cachedCmdData;
        public static UIApplication CachedUiApp
            get
                return _cachedCmdData.Application;
        public static RvtApplication CachedApp
            get
                return CachedUiApp.Application;
        public static RvtDocument CachedDoc
            get
                return CachedUiApp.ActiveUIDocument.Document;
        #endregion
        #region IExternalCommand Members
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            _cachedCmdData = cmdData;
            try
                FilteredElementCollector collector = new FilteredElementCollector(CachedDoc);
                collector.OfCategory(BuiltInCategory.OST_IOSModelGroups).WhereElementIsNotElementType();
                List<Element> els = collector.Cast<Element>().ToList();
                Element el = els.First();
                Group g = el as Group;
                BoundingBoxXYZ box = g.get_BoundingBox(CachedDoc.ActiveView);
                XYZ p1 = box.Max.Add(box.Min) / 2;
                XYZ p2 = p1.Add(new XYZ(0, 0, 1));
                Line ln = Line.CreateBound(p1, p2);
                using (Transaction t = new Transaction(CachedDoc, "Revit"))
                    t.Start();
                    ElementTransformUtils.RotateElement(CachedDoc, el.Id, ln, Math.PI / 2);
                    t.Commit();
                return Result.Succeeded;
            catch (Exception ex)
                msg = ex.ToString();
                return Result.Failed;
        #endregion
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 11 of 19
stever66
Thanks & Regards
For step 2, don't you mean:
min + (max - min)/2  ?
Message 12 of 19
Mustafa.Salaheldin
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.IO;
#endregion
            get
            get
            get
        #endregion
            try
                    t.Start();
                    t.Commit();
        #endregion
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 13 of 19
Dear Mustafa,
I don;t know but I see a bonding getting developed here.Smiley Wink Thanks for spending time for me. Can I have your emailid?
I tried your code and you can see the results in the image below.
Message 14 of 19
Mustafa.Salaheldin
You have to adjust the angle in the code because it is already set to 90 degree (Math.Pi / 2).
I've modified the code to make you able to control the value of the angle.
If this reply satisfies your need please don't forget to mark it as solution.
 This code will rotate the group by 180 dgree now.
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.IO;
#endregion
            get
            get
            get
        #endregion
            try
                    t.Start();
                    //control the rotation angle from here.
                    double RotationAngle = Math.PI;
                    ElementTransformUtils.RotateElement(CachedDoc, el.Id, ln, RotationAngle);
                    t.Commit();
        #endregion
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 15 of 19
don;t know what's going wrong;
my code with your help goes like this:
trans.Start("sun");
XYZ targetPoint = Command.uidoc.Selection.PickPoint("Please pick a point.");
Group dt = uidoc.Document.Create.PlaceGroup(targetPoint, ty);
BoundingBoxXYZ box1 = dt.get_BoundingBox(Command.doc.ActiveView);
XYZ p1 = box1.Max.Add(box1.Min) / 2;
ElementTransformUtils.RotateElement(Command.doc, dt.Id, ln, 180);
result:
Message 16 of 19
Mustafa.Salaheldin
Revit uses the radian measurments for angel so your code should be:
trans.Start("sun");
// replace 180 with Math.Pi
ElementTransformUtils.RotateElement(Command.doc, dt.Id, ln, Math.Pi);
To rotate around the arbitary point
trans.Start("sun");
 XYZ p1 = targetPoint ;
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 17 of 19
sorry but the revised code did nothing. In fact it even didn;t got rotated
Message 18 of 19
Mustafa.Salaheldin
Sorry it was my mistake Smiley Sad
trans.Start("sun");
ElementTransformUtils.RotateElement(Command.doc, dt.Id, ln, Math.PI);
 I forget to repalce the 180 by PI Smiley Very Happy
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 19 of 19
Dear Mustafa,
Thanks for you time and help. Your code did the trick only with a very very little minor change.
trans.Start("sun");
//ElementTransformUtils.RotateElement(Command.doc, dt.Id, ln, Math.Pi);
//Replaced above line with
ElementTransformUtils.RotateElement(Command.doc, dt.Id, ln, rotation defined bu user * Math.PI / 180);
Again a big thank for you. Kudos to you and I will accept your solution as accepted answer. But I want to carry it forward. I am posting a new query in the forum. I which I will be needing your expert suggestion.
Thanks & Regards
