Copy sheets along with views and schedules using revit Apis
bhargavsKZ39V
bhargavsKZ39V
Hi Everyone , By using copy method,
 ElementTransformUtils.CopyElements(linkedDoc, Sheet_ids, doc, Transform.Identity, new CopyPasteOptions());
i can copy sheets from source file to destination file but i couldnt copy views and schedules placed on that  sheets , please suggest some solution for coping sheets along  with views and schedules paced on that sheets , Thanks in advance
jeremy_tammik
Have you looked at the DuplicateViews Revit SDK sample?
DuplicateViews
Subject: Copy paste drafting views and schedules from one document to another
Skill Level: Medium
Category: Elements, Views
Type: ExternalApplication,
Revit Platform: All
First Released For: 2014.0
Classes: Autodesk.Revit.DB.CopyPasteOptions
Autodesk.Revit.DB.ElementTransformUtils
Autodesk.Revit.DB.FilteredElementCollector
Autodesk.Revit.DB.IDuplicateTypeNamesHandler
Autodesk.Revit.DB.IFailuresPreprocessor
Autodesk.Revit.UI.IExternalCommand
Summary:
Use the copy paste APIs to copy drafting views and schedules from one document to another. The drafting view contents will also be copied.
bhargavsKZ39V
Hi Jeremy, thanks for reply ,through above code i can copy views and schedules, but exactly what I want is copy view sheets from one document to other, when i do that , I can copy only empty sheets (blank sheets) , I want views placed on sheets also copied along with that sheets
bhargavsKZ39V
Any revit apis avaialable for above insert views from file, because thats how maually we can copy sheets from other documents? thanks in advance
