Copy/Paste Formatted text from TextNote to clipboard
pschleppy
pschleppy
I am trying to copy the content of the TextNote into Clipboard. Currently I have following code. The code copies text into clipboard without formatting. Is there a way to copy content of a TextNote along with its formatting?
var elem = doc.GetElement(pickedRef);
var textNote = elem as TextNote;
System.Windows.Clipboard.SetData(System.Windows.TextDataFormat.Text.ToString(), textNote.Text);
jeremytammik
Dear Paul,
Thank you for your query.
TextNote.GetFormattedText?
http://www.revitapidocs.com/2017/a1e3b2d7-0d56-55f9-6b30-1c5269dc39e0.htm
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
pschleppy
What is data format of data in FormattedText class? I would like users to be able to copy the data to MS Word.
solvedplus
hi,
i have tried all options of formatted text with clipboard but text with format can't be copied to clipboard
what do we miss?
thanks
gdavis479JP
Here is the code that seems to work.  Originally got the idea from Martin Schmid (thanks)... Googled to find how again and found this forum entry (which often are incomplete), so now that I further researched - here it is...
Not 100% sure which of these two are need (or both) but using...
using System.Windows;
using System.Windows.Forms;
INSIDE YOUR CODE... where:
string catalogProductItemInfo = "The string of text you want to go to clipboard (or other variable - text info etc)";
call this:
Clipboard.SetText(catalogProductItemInfo);
