Copy Elements
Copy Elements
Copy Elements
I'm using element transform utils to copy groups from one document to another (which worked fine in 2018) but now get an error in 2019 - "Some of the elements cannot be copied, because they are view-specific.
HELP!
zhong_wu
Autodesk Support
Autodesk Support
I am sorry but what is "element transform utils"? Is that a tool or something API related? Can you provide more details so we can help check more? Thanks.
John Wu
Developer Technical Services
Autodesk Developer Network
Ning_Zhou
same problem when copying textnote across documents
ElementTransformUtils.CopyElements(doc, copyIds, targetDoc, Transform.Identity, new CopyPasteOptions());
Ning_Zhou
solved, need to use views instead of documents
