Copy dimensions from a View to another
t.galland
Message 1 of 21
t.galland
I'm trying to create a new plug-in on Revit 2016/2017 with the API. The idea is to copy a set of element from small revit file to a central one to compile them.
Here is the code I'm using :
UIDocument mainUiDoc;
Document mainDoc;
string mainPath;
UIDocument secUiDoc;
Document secDoc;
try
    mainUiDoc = app.ActiveUIDocument;
    mainDoc = mainUiDoc.Document;
    ViewPlan mainView = (ViewPlan)mainDoc.ActiveView;
    mainPath = mainDoc.PathName;
    XYZ extremitePoint;
    Selection sel = mainUiDoc.Selection;
    extremitePoint = sel.PickPoint("Selectionner le coin sup. gauche de la feuille");
    secUiDoc = app.OpenAndActivateDocument(((RevitFile)Main._roomData["revit"]).Path);
    secDoc = secUiDoc.Document;
    FilteredElementCollector collector = new FilteredElementCollector(secDoc);
    ViewPlan secView = collector.OfClass(typeof(ViewPlan)).Cast<ViewPlan>().First(
        x => x.ViewType == ViewType.FloorPlan &&
        x.IsTemplate == false &&
        x.Name.Contains(((RevitFile)Main._roomData["revit"]).Typology, StringComparison.OrdinalIgnoreCase));
    secUiDoc.ActiveView = secView;
    FilterableValueProvider provider = new ParameterValueProvider(new ElementId(BuiltInParameter.ALL_MODEL_TYPE_NAME));
    FilterRule rule = new FilterStringRule(provider, new FilterStringContains(), "BY_GO", false);
    ElementParameterFilter epf = new ElementParameterFilter(rule, true);
    ICollection<ElementId> npText = new FilteredElementCollector(secDoc, secView.Id).WherePasses(epf).ToElementIds();
    using (TransactionGroup tx = new TransactionGroup(mainDoc, "Insert"))
        ICollection<ElementId> pastedElements;
        tx.Start();
        using (Transaction tr = new Transaction(mainDoc, "Copy elements"))
            tr.Start();
            FailureHandlingOptions failOpt = tr.GetFailureHandlingOptions();
            failOpt.SetFailuresPreprocessor(new WarningSwallower());
            tr.SetFailureHandlingOptions(failOpt);
            pastedElements = ElementTransformUtils.CopyElements(secView, npText, mainView,null, new CopyPasteOptions());
            mainDoc.Regenerate();
            tr.Commit();
        using (Transaction tr = new Transaction(mainDoc, "translate elements"))
            tr.Start();
            pastedElements = new FilteredElementCollector(mainDoc, pastedElements).WherePasses(epf).ToElementIds();
            BoundingBoxXYZ floor = new FilteredElementCollector(mainDoc, pastedElements).OfClass(typeof(Floor)).First().get_BoundingBox(null);
            XYZ originePoint = floor.Min;
            XYZ translation = extremitePoint - originePoint;
            translation = new XYZ(translation.X, translation.Y, 0);
            ElementTransformUtils.MoveElements(mainDoc, pastedElements, translation);
            tr.Commit();
        using (Transaction tr = new Transaction(mainDoc, "rotate elements"))
            tr.Start();
            Line rotation = Line.CreateBound(extremitePoint, new XYZ(extremitePoint.X, extremitePoint.Y, extremitePoint.Z+10));
            ElementTransformUtils.RotateElements(mainDoc, pastedElements, rotation, - (double)Main._roomData["rotation"] * Math.PI / 180);
            tr.Commit();
        using (Transaction tr = new Transaction(mainDoc, "miror elements"))
            tr.Start();
            Plane mirror = null;
            switch ((string)Main._roomData["Symétries"])
                case "nulle":
                    break;
                case "horizontale":
                    mirror = new Plane(new XYZ(1, 0, 0), new XYZ((floor.Max.X + floor.Min.X) / 2, (floor.Max.Y + floor.Min.Y) / 2, 0));
                    ElementTransformUtils.MirrorElements(mainDoc, pastedElements, mirror, false);
                    break;
                case "verticale":
                    mirror = new Plane(new XYZ(0, 1, 0), new XYZ((floor.Max.X + floor.Min.X) / 2, (floor.Max.Y + floor.Min.Y) / 2, 0));
                    break;
                default:
                    break;
            tr.Commit();
        tx.Assimilate();
When I use it, everything is good except the dimensions. They are inside the new document (I can get them with there id and RevitLookup) but they are hidden. If I select on of them and add a witness line the dimension is now visible again. I tried to close and reopen Revit and place the vien on a sheet bt nothing.
Any idea ?
Thank you !
Replies (20)
Message 21 of 21
Joris.vd.Meulen
@Admin I copy pasted my post in order to keep forum clean
Guys,
I've created a dimension which isn't visible in my view.
Read this topic: https://forums.autodesk.com/t5/revit-api-forum/newdimension-dimension-created-but-not-visible/m-p/63... where people too have this matter.
Any clues how come?
I do can select the dimension.
Is there any way I can debug it?
- I checked my get_Geometry(opt) ... true etc.
- References are parralel
- line
Like: is the dimension isn't visible, but placing another dimension, select of in entire project gives me 2 dimensions instead of 1, ... where is it placed?
Snooping that dim gives me:
- the dimension's ID I can't see
- it referers to surfaces of a mullion
- that mullion ID:
- I select in Revit and that gives me a mullion which isn't in my project???? So like a ghost mullion.
Screencast:
https://autode.sk/2qGnjCk
love python coding
